Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 08-16-2018, 06:42 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Removal of Fabric Covered Cabinet Inserts
Our 1989 Excella has couch matching fabric panel on the end caps of the cabinets on both sides of the trailer (kitchen cabinet and cabinet above the TV.
Does anyone know how to remove and replace these panels? We want to recover with the same fabric ice on our couch reupholster job.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 08-18-2018, 09:37 AM   #2
1988 29' Excella
North East , Maryland
Hi,
We have a 1988 Excella 29 and just removed our corner inserts. Carefully pry off the frame around the fabric inserts. Ours are oak and they came off very easily. Our oak needs refinished and only had a few small finishing nails holding them. The padded fabric insert is a separate piece and it is fabric stretched over a foam pad with a single button in the center to luck like tufting. We are trying to decide whether to replace with new, matching fabric (to the sofa) or use oak plywood finished like the cabinetry. We will not make the final decision until it is time to put the interior back together
Also check the back bedroom if there is any overhead cabinets with an end. There may be another corner insert.
Ladyfish is offline   Reply With Quote
Awning Fabric Removal Help Please Re-Pete Awnings 23 10-06-2017 04:10 AM
Interior fabric removal Anniejo Interior Restoration Forum 4 06-19-2015 10:09 PM
'85 Galley O/H cabinet end cap fabric replacement krohnjs Upholstery, Blinds, Walls & Interior Finishes 1 07-26-2011 08:20 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Wood Inserts on the Fridge? Porky Pig Refrigerators 18 11-12-2003 03:22 AM
