09-26-2020, 01:15 PM
2015 23' FB International
Dallas
Dometic AC unit won’t turn on
I have a 2015 23FB International, and the female plug on the circuit board disconnected from the board. I replaced the thermostat and plugged it into the phone-type cord. The thermostat does not give an E1 code on Zone 1, so it appears to be working fine.
I don’t have a 240v plug where my AS is stored. So, I connected power only to my truck, leaving the truck running. The Dometic AC unit will not kick in, not even the fan by itself. Does the AS need 240v land power for the unit to run? The breaker is not tripped.
09-26-2020, 01:20 PM
2002 25' Safari
Dewey
Air Conditioning units require 120 volts of AC shore power.
Richard
09-26-2020, 01:26 PM
2018 25' International
Slidell
, Louisiana
The AC controller uses 12V power but the Fan and compressor requires 120VAC shore power. Sounds like you have 2 ACs and 50A service. The 50A service is indeed 240 and a neutral, but the Airstream power center does not use the 240V. Instead it uses a hot and the neutral so 120V and it is split into two services so you have 100 Amps of 120V total capacity.
Because of this,you will want to be sure if you run into 30Amp service and use an adapter, you want to be sure the service is 120V 30A not 240V 30A. Household dryers use 240V 30A. Campgrounds are use 120V 30A.
09-26-2020, 01:56 PM
Dallas
Thanks. There is one AC unit.
09-26-2020, 02:06 PM
Slidell
, Louisiana
Ah, okay the same caution applies. Be sure the 30A service is wired for 120V (one hot, one neutral and one ground). To test the AC you can get a 15/20A to 30A RV adapter. With everything else off especially the water heater, 15A 80% of the time will start and run the AC. It should only draw 13Amps running, 17-18 amps starting.
09-26-2020, 02:22 PM
1987 Avion 34W owner
Good Ol'
, USA
It sounds lke you are extremely fortunate that there was NOT a 220 connection available where you store your AS, or the power system and who knows what else might be fried by now.
Please be aware that your Airstream needs 120V input.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
09-26-2020, 02:30 PM
Dallas
Well, I have obviously used the plug over the years at campgrounds, with the 30-amp circuit. It looks different from a typical 120v plug. Regardless, will the AC unit run, even just the fan, with power slowly from the tow vehicle? Or, does it have to be plugged into shore power?
09-26-2020, 02:34 PM
Dallas
I just found in the manual that the unit likely will not run without at least 105v. I assume that power from the tow vehicle is nowhere near that. Correct?
Good Ol'
, USA
You will need shore power.
1987 Avion 34W
09-26-2020, 02:35 PM
Good Ol'
, USA
Your tow vehicle will only provide 12VDC through the trailer connector.
1987 Avion 34W
09-26-2020, 02:37 PM
Dallas
Thanks! Can I use an adapter from a typical three-prong grounded plug to that used on the AS, and plug the three-prong into my truck since there is no power at the storage site?
09-26-2020, 02:44 PM
Good Ol'
, USA
You have AC power available from your truck?? I have seen that on newer vehicles (please know that my tow vehicle is a 1995 F250. nothing that fancy on my truck... ), but that won't provide much amperage.... those connections are for low-power needs like charging a phone.
1987 Avion 34W
09-26-2020, 02:47 PM
Dallas
Yeah. It’s awesome. Real-live plugs.
09-26-2020, 03:10 PM
Slidell
, Louisiana
I'm guessing the inverter in your truck is pretty small, probably less than 200 watts. You'd need a 2200 watt inverter to run the AC.
09-26-2020, 03:28 PM
Dallas
Thanks again for all of your help.
09-26-2020, 03:34 PM
2007 22' International CCD
Corona
Toyota Tacoma has a single standard 120 volt AC plug in the bed. It’s only good for 200 watts while driving, 400 when in park. It’s not going to even start an air conditioner blower...
I use mine to run a small battery charger for the generator starting battery on the road. It’s kinda wimpy as far as most inverters go. Tundra doesn’t have one.
