06-11-2022, 03:02 PM
Reformed Engineer
1967 26' Overlander
1987 32' Excella
2000 35' Land Yacht XL w/2 slides
_
, _
Poor city water pressure, 2000 Land Yacht 355XL
Hi
2000 Land Yacht 355XL (Ford V10 chassis)
Water pressure is lousy at all fixtures in this motorhome, even at campsites of known healthy city pressure. No leaks. No inline regulators between supply and hose or hose and house. No kinks in hose. Fresh tank inlet valve off. Flow at indoor and outdoor showers is pitiful. If I switch on the pump while city water connected,, pressure increases a good bit though not as much as I'd like. I replaced the inlet plate, which I think contains a vacuum regulator? That seemed to help a little too, but still not enough. Suggestions?
Dave
06-11-2022, 03:27 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Have you removed any faucet aerators and tried water flow etc. w/o it installed?
06-12-2022, 06:01 AM
Reformed Engineer
1967 26' Overlander
1987 32' Excella
_
, _
There are no aerators on the shower wands
06-12-2022, 06:26 AM
2008 22' Safari
Spicewood (W of Austin)
Many shower hoses/wands have a plastic restrictor-washer (water-saver) inside the fititngs which can be removed to increase flow.
06-12-2022, 07:01 AM
Somewhere
, South Carolina
Pic of water hose to shower head connection from my rig. That "thing" inside the connection sure could collect crud etc.
I'd consider PROVING that the inlet/regulator is passing at designed flow and not restricted.
06-12-2022, 08:05 AM
1994 34' Excella
Warren
, Manitoba
You indicate that water pressure is low while on city water. Is the pressure low while using the onboard water tank and pump as well? If low while only on city water, I would look for a restriction in the line from the city water inlet to the "tee" where it attaches to the line from the water pump. I have seen pieces of the rubber washer from the garden hose connection restricting the line. You might have to cut the line prior to the tee and clean out. Has this problem just appeared, or has it been this way since aquiring the rig?
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
06-14-2022, 04:26 AM
Somewhere
, South Carolina
EngiDent,
Any luck?
Posting conclusions helps others learn what to look at and what the fix was.
Gary
07-22-2022, 09:31 AM
Reformed Engineer
1967 26' Overlander
1987 32' Excella
_
, _
Thanks for replies. The low pressure issue is coach-wide... Inside shower, outside shower, both sinks. If I toggle the fresh water pump while connected to city water, I get a slight increase in flow, but still nowhere near normal. I believe there has to be a regulator buried in the bowels of this thing. I doubt it is a flow *restriction* because a restriction would limit flow rate, not pressure, and there is no surge upon faucet opening. I do not use an inline regulator between spigot and city water connection. There are two backflow preventers, one built into the city water panel, the other is a Watts 288A mounted under the sink that I think is for either the toilet line or the water tank (I have a black tank flusher but there is no internal supply, only connect separate hose from outside.) I have replaced the city water panel / connector / backflow preventer and it made little or no difference.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
2000 355XL wiper pivot assembly
EngiDent |
Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes |
0 |
06-30-2021 07:32 AM |
Tire pressure, 2000 Land Yacht 355XL
EngiDent |
1 |
06-21-2021 02:08 PM |
355XL TV antenna wiring problem
EngiDent |
4 |
06-21-2021 10:16 AM |
Water Pressure: Shore pressure high, All pressure in trailer low....
bhooves |
Sinks, Showers & Toilets |
9 |
10-16-2016 03:22 PM |
'71 overlander poor water pressure on waterpump.
neokans |
Plumbing - Systems & Fixtures |
2 |
02-28-2010 01:11 PM |
