Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 08-03-2021, 02:55 PM   #1
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , New Mexico
HWH Leveling jack problem
We have a HWH 210 leveling jack system on our coach.
The left rear jack will go down and raise the coach, but it will slowly creep back up (it probably takes over night or the next day for it to retract fully).
The jack shows no indication of leaking so I am thinking I may need the PLUNGER AND GUIDE (FOR
RETURN).
Does anyone have any experience with this? Are there any instructions for this repair available?
BarnacleBill is offline   Reply With Quote
Old 08-03-2021, 04:54 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
RETURN).
check this :
http://www.hwhcorp.com/ml11428qr_009.html
They are also happy to sell you a new leveler for a lot of money ($700-800) or rebuilt yours
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 08-04-2021, 01:21 PM   #3
Streamin'
I did the rebuild at the HWH plant in Moscow ID in 2013. I think this is a new problem...
Old 08-09-2021, 09:34 AM   #4
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
I had that problem while staying in West Virginia one winter. Cold will definately affect the fluid. Have you checked the fluid level in the system tank? If its gets low it does not retract very well. I also had seals on both front levelors rebuilt while in Montana. Take them to a tractor shop for quicker cheaper repair when needed.
Mike1997 is offline   Reply With Quote
Old 08-10-2021, 11:11 AM   #5
Streamin'
Yep. Checked the level Thanks
HWH Leveling jack problem BarnacleBill General Motorhome Topics 0 08-03-2021 02:51 PM
HWH leveling jack repair. Kota Mechanics Corner - Engines, Transmission & More... 1 11-11-2020 08:51 AM
HWH leveling Jack replacement PeterH-350LE Mechanics Corner - Engines, Transmission & More... 17 11-01-2020 07:20 AM
