Old 10-24-2021, 09:04 AM   #1
1987 34.5' Airstream 345
AUBURN , WA
Air compressor not working
I'm a new owner of a 1987 345.
The air compressor doesn't come on when the engine is started. The bags are at 7".
Where do I start with this fix? The prior owner had it sitting for 5 yrs.
MyKalakala is offline   Reply With Quote
Old 10-24-2021, 11:31 AM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Welcome to the forum, you are in the right place. I would start with a multimeter and test the connections at the compressor when it should be running. You might have a Schrader valve curb side between the rear wheels, if so you can check pressure there and fill the system in a pinch. If not, there will be a valve at the bottom of the air tank, it lets you drain water from the tank and can also be used to check pressure/air up.
Waipio Rim is offline   Reply With Quote
Air compressor for rear airbags not coming on GinaParmesan Classic Motorhomes 26 11-28-2018 11:55 AM
Air bag pressure getting lower and air horn not working 92landyacht Mechanics Corner - Engines, Transmission & More... 26 11-12-2018 01:46 PM
Air Compressor External Hose Not Working Ripley345 Airstream Motorhome Forums 4 12-01-2016 02:23 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
