08-23-2019, 10:28 AM
Livingston
, Full time traveler
Replacement for Atwood Protector 2001 Series LPG Alarm?
Thanks in advance
Airstream of Consciousness
08-23-2019, 11:09 AM
2012 25' FB International
Trent Woods
, North Carolina
https://www.amazon.com/Dometic-Hydro...gateway&sr=8-1
Is this what it looks like? Comments seem to indicate it fits. This is what I just bought as a replacement for mine.
Larry
08-23-2019, 09:36 PM
2008 30' Classic S/O
Hampton Beach
, New Hampshire
Replacement Detector
I just did this last week, the original finally failed after 8+ years...the new version is slightly smaller. Surface mounting in the same spot as the last detector leaves the old screw holes visible. With a little colored putty you've gotta look for it. Works just fine.
https://www.campingworld.com/atwood-...ite-82278.html
All the best!
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
08-27-2019, 01:41 PM
Livingston
Originally Posted by lsbrodsky
This is what I too got from Amazon
Fits perfectly.
04-10-2020, 09:59 AM
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
LPG and CO monitor New all in one Atwood
Just received my combo CO and LPG monitor, going to replace the existing, so I will need a larger cutout but now can get rid of the CO battery detector in the bedroom area.
https://www.ebay.com/itm/ATWOOD-RV-D...sAAOSwTvFd0Ik8
Laurence
04-10-2020, 11:04 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by HCR
Thanks in advance
Our '03 has a surface mount, no square hole in the panel.
Is yours the same?
Ordered this as the replacement, no panel hole needed.👍
The original...going to use the same disconnect switch.
04-20-2020, 10:28 AM
GVA
, British Columbia
Update re: replace Propane monitor 27FB
Originally Posted by LAWBC
Update to those having to replace their Propane monitor
So as stated I received and installed the new combo Propane gas and CO monitor. After the install I did not have power to the unit and found by searching that I blew the inline one amp fuse. It is a bear to get at in the 27 FB as it is located in the front storage electric DC relay for the cut off switch and bus bar distribution, partitioned off with a plywood panel held by a couple of L brackets so freed up the forward end bracket only. The fuse was zip tied to a bundle of other wires which had to be free in order to get to the fuse holder then unscrewed the positive lead end from the bus bar,,, then I was able to pull the fuse holder out from the front hatch and get a couple of pliers and gently squeeze it apart (yes it was not very pliable ).
I purchased a "slow Blow" one Amp fuse to replace and so hopefully it shouldn't happen again. All is good and works fine now.
I know I could have moved the fuse but by the time I got to it I was not going to add one more damn step to the program and yes I could have placed the wire on the relay side to be able to place it in store mode but did not do that either ( I might go in there again and do that or not). I do have a 160watt Go Power solar system keeps batts up.
Laurence
12-01-2020, 04:37 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Cannot find replacement.
Hi all. My LPG detector in the 2014 25ft finally signaled that it was time. I have had no luck as every source I go to says "currently unavailable"
I have tried all the usual. Amazon, e-trailer, ebay etc. Any ideas?
Thanks.
12-01-2020, 06:20 PM
Hampton Beach
, New Hampshire
RV Propane Detector
Thanks.
Web search engine - RV Propane Detector
https://www.rvpartscountry.com/RV-LP-Gas-Protector.html
Best!
Tom - S/OS #025
12-01-2020, 07:43 PM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Thanks a bunch. Have to see if they ship to Canada.
12-01-2020, 07:52 PM
2013 25' FB Flying Cloud
Longmont
Thanks.
I replaced the detector in my 2013 about a year ago. I could not find the same model name, but I found what looks like the same model under a different name, and only in white instead of brown.
Dyer's says they have one in stock at the moment:
https://www.dyersonline.com/atwood-w...rotechtor.html
Dyer's also has some other models of different sizes.
PPL Motorhomes also has some models in stock, though I did not see one that would fit the hole in my 2013.
12-03-2020, 04:31 PM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Thanks to all for your replies. I should have called my dealer (Midtown RV) in the interior first as apparently Airstream has replaced the unit with another similar model (Thanks SSquared) that seems to have the correct dimensions. Only issue is that it is only available in white but as long as it works.
