01-03-2021, 12:23 PM
2021 23' Globetrotter
Park City
, Utah
Want to Trade my 30lb Propane Tanks for your 20lb Tanks
I am working on lowering the tongue weight on my 2019 Airstream Globetrotter 27FB. It came from the factory with (2) 30lb propane tanks. They are both full.
The AS is located in storage in Salt Lake City, UT. I would like to trade my (2) 30lb tanks for (2) 20lb tanks. If anyone is interested, please let me know.
Happy New Year!
--Susan
--Susan
01-03-2021, 01:24 PM
2016 16' Sport
Miami
I’m sure you are familiar with your own propane needs but have you considered just using one 30 gallon tank?
01-03-2021, 01:36 PM
2019 27' International
Western NC
, North Carolina
Or upgrade to aluminum tanks.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
01-03-2021, 01:42 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Happy New Year!
--Susan
Not sure about your budget but one thing I did to reduce weight on the tongue was to replace two lead/acid batteries for one lithium. Saved about 90 lbs.
FWIW
01-03-2021, 02:19 PM
Park City
, Utah
The plan to reduce tongue weight is:
--Replace the 30lb tanks with either 20lb tanks or aluminum tanks. (looking at composite tanks, but safety is an unknown without further research)
--Replace the batteries with Lithium
--Remove the spare wheel and tire.
Thanks @jondnc for the aluminum tank suggestion.
--Susan
01-03-2021, 03:16 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Check the specs ... you will not save much weight with the alum tanks ... most of the weight comes from the propane inside.
01-03-2021, 05:34 PM
I don't know the specs. of your trailer, but keep in mind, you do need a certain amount of tounge weight to be safe. Having to little tounge weight can be worse than to much.
Enjoy,
Paul Waddell
01-03-2021, 07:33 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
What are you towing with that you need to reduce the tongue weight so significantly?
Do you know what the actual tongue weight is? Have you measured it?
I have use composite tanks with success, but there are quite a few modifications that must be made in order to get them to fit properly.
One sure fire way to reduce tongue weight other than removing items from the tongue is to add weight to the rear behind the axles. This of course will add to the overall trailer weight which might also be a concern.
Also if you add weight to the rear it should be done with a scale so you can truly see where the weight is being moved.
Ultimately having your tow vehicle/trailer combo set up by a professional or at least get professional advice is the best place to start.
01-03-2021, 08:34 PM
Park City
, Utah
I'm consulting with CanAm regarding the towing setup. I'm pairing the new Land Rover Defender 110 HSE with a Globetrotter 27FBT. The Defender has a towing capacity of 8201 lbs, but a max tongue weight of 771 lbs. The Globetrotter's GVWR is 7600. I can shave off about 200lbs from the current tongue weight between the batteries, propane tanks, and spare wheels and tires. I'm also having the factory hitch professionally reinforced.
--Susan
01-03-2021, 08:53 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Disclaimer....I noe nothing.
Get a tow vehicle that won't need any "improvements". Improve the AS, Never mind, yours seems made-up.
POI do not go by the AS published tongue weight, the loaded for travel AS will be heavier.
Sweet Streams.
01-04-2021, 09:35 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
I guess I'm in the Robert Cross camp in lots of ways - buy an AS that matches the factory spec of the vehicle as it stands or buy a vehicle that can safely tow the AS you want. Three words -Safety, Liability, Lives. But what do I know, I've seen pictures of an AS being towed by a bicycle (I wonder what modification they did to do that?)
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
01-04-2021, 09:40 AM
2020 25' Flying Cloud
lake Wales
reducing tongue weight
I did also did all of the above. I moved the spare to the roof rack of my SUV, but it created too much wind noise, so I moved it back. Some travel with no spare since they have road service, as I do. Not quite ready to do that.
One other change - I carry my Honda 2200 propane generator in a rubber maid case over the rear axil, rather than in the the TV. Use 2 spring loaded shower rods to hold it in place. I may figure out a more secure holding system, but did not want to modify the floor by routing in a hold down. Little bit of a hassle, but not much. I am older and moving 50 lb items is a bit much, but I will stick with it. I ordered my generator pre converted to propane. No gas issues carrying it inside the TV or AS.
I have not been able to find reasonably priced aluminum tanks. I purchased 2 new 20 lb, but now I just carry one 30 lb if I need to drop the weight 35. I use the 20's for my grill.
From my experience towing about 3000 miles in the past year, is I need to not have the tongue wt too low. It gives it a slight bobbing. If I run at 12-13%, it tows very nicely. I also switched to a ProPride 3 hitch. Pricey, but I have not had any sway since I made the change. It also does not move when trucks pass or I have a strong cross wind.
e
01-04-2021, 09:52 AM
2016 28' International
Trois-Rivieres
, Quebec
I concur. Tongue weight and overall load balacing is fundamental in avoiding trailer sway (see video). Lots of vehicles can tow a 7600lb 27' (I think it's actually 27' 11") Airstream, but doing so comfortably (no white knuckles) on more challenging roads and grades is another matter.
In addition, if you are to camp during the shoulder seasons, you will need that extra propane; two 30lb tanks is not a luxury when your furnace is running to keep the inside temperature and your water lines from freezing.
But then, I will not argue with Can-Am RV and Andy Thompson on matters of rig setups...
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
01-04-2021, 10:00 AM
1977 31' Sovereign
Rochester
, WASHINGTON
Adding weight behind the axles of any RV leads to dangerous sway conditions.Thats how these new to towing drivers roll combination rigs.
Giving that advice , especially to those new to towing, is not a good idea.Especially if they have a single axle trailer.The weight is much better forward.
Jus sayin...
01-04-2021, 10:03 AM
1977 31' Sovereign
Rochester
, WASHINGTON
Happy New Year!
--Susan
If you need to worry about tongue weight like that, you need a real tow vehicle.Dont let your trailer drive your rig.
01-04-2021, 10:11 AM
1977 31' Sovereign
Rochester
, WASHINGTON
Happy New Year!
--Susan
01-04-2021, 11:39 AM
2017 30' International
Lincolnwood
tongue weight
e
My TV is a ford f250. I recently took the truck spare tire and put it into the bed of the truck, forwards of the rear axle. My understanding is that anything behind the rear axle needs to be included in the tongue weight. Truck tires weigh alot ,80 lbs+. When traveling I put all of the heavy stuff in front of the rear axle. I am also considering removing the trailer spare and placing it on top of the truck spare. Not sure what a 15 inch GYE weighs with rim but probably 50-60 lbs. That, according to my calculations removes 140 lbs of tongue weight.
Just remember when calculating tongue weight, to add what you carry in your vehicle that is placed behind the rear axle to that weight. It's not just the actual trailer hitch weight that needs to be figured into the calculation. You want to avoid overloading the rear axle. If you take too much weight off the front of the vehicle you will create steering problems.
What is your vehicles payload ?? I think you need a more capable tow vehicle.
What class is your hitch ?? Read the sticker and see what the ratings are with and without weight distribution. You may be making a mistake that puts your safety at risk.
01-04-2021, 12:12 PM
Western NC
, North Carolina
I think you maybe chasing the wrong numbers. My understanding is tongue weight is the additional weight added to the truck when you connect the trailer. So if you take your truck to the CAT scale loaded for camping no trailer you have a base weight on the truck. Connect the trailer no weight distribution. Go to CAT scale weigh the rig, your have a new set of front and rear axle weights. Add them up, subtract weight with no trailer. That’s the effective tongue weight you added.
01-04-2021, 12:13 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
You could also save weight using your existing tanks by just not filling to full capacity. Tell the LP station that you only want them to fill to four (4) gallons.
The weight difference between a steel 20 lb tank and a 30 lb tank empty is only two (2) lbs. So you would only be saving a total of four (4) lbs. by doing the swap.
01-04-2021, 12:17 PM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
Get the composite tanks. Same end game, bit more costly, but meets all your criteria.
https://www.vikingcylinders.com/products/
