Easy digital thermostat upgrade
I decided to upgrade the thermostat in my 2021 Bambi today. Why they are still using mechanical thermostats on a $50,000 trailer is beside me but this is a cheap easy upgrade for anyone that wants to do it. For trailers that have a heat only furnace you only have two wires they are R and W, your mechanical thermostat will have labels on the terminal take it off the old thermostat and hook it up to the new one. These non programmable digital thermostats run off of two AAA batteries, what is nice is you also have a digital readout of the temperature in the trailer now. I used a Honeywell TH1100DV1000/U Pro 1000 total cost was about $26. just be sure to get a vertical thermostat so that you cover the mounting holes of the original thermostat
