Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 09-01-2017, 04:54 PM   #1
2018 27' International
Seattle , Washington
Aluminum propane tanks, yea or nay?
When I was last at my dealer, I spotted aluminum propane tanks.
Who's done the swap, and are you glad you did?
Where'd you get yours? I have to assume there's a cheaper source than the dealership.
Will the 40# tanks I see online that are sold as being for forklifts fit in a 2018 27' Serenity's existing compartment?
Is there a substantial weight savings?
FarFetched is offline   Reply With Quote
Old 09-01-2017, 06:04 PM   #2
PKI
PKI's Avatar
Walnut Creek , California
Expensive and not that much lighter in weight - 5#s? High on cool factor, but light on value. Vintage Trailer has them for about $220. Would like to have a set, but can't justify the price of admission. Pat
Old 09-01-2017, 07:06 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Aluminum tanks do not rust, but must be inspected just like steel tanks and must have OPD valves. We have the original aluminum tanks on our 1979 Safari. They are cool and can be polished. We obtained the aluminum tanks for our Liner from Vintage Trailer Supply.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 09-01-2017, 07:11 PM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Fork lift tanks are normally horizontal tanks. Tanks on most trailers are vertical, though some are not. One cannot be changed with the other since the internal mechanism that collects the vapor have to be in the correct orientation. If the orientation is not correct liquid propane will be collected instead of vapor (LP gas). RV appliances are not designed to use liquid.
The 30 lb steel tanks are shorter than the 30 lb aluminum tanks.
The 30 lb aluminum tanks are shorter than the 40 lb aluminum tanks.
If you change from either 30 lb tank to 40 lb the cover will not fit correctly.
I changed from 30 lb aluminum to 40 lb aluminum on my 34'. Even though there is some flexibility in height, the cover is 4-5" to short now.
I decided to stay with steel tanks on my 25'.
add edit:
You can find the dimensions of various tanks here
http://worthingtonindustries.com/get...m.pdf?ext=.pdf
Alan
Old 09-01-2017, 07:37 PM   #5
1976 29' Ambassador
Dallas , Texas
While I understand PKIs stance I'm planning on buying the 40# aluminum tanks. The aluminum weigh 21# each vs steel at 32# each.
But it is over twice the price.
tabney0315 is offline   Reply With Quote
Old 09-01-2017, 07:38 PM   #6
1976 29' Ambassador
Dallas , Texas
You can get them from VTS. http://www.vintagetrailersupply.com/...-p/vts-172.htm
Old 09-01-2017, 08:50 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I really like the aluminum tanks. IMHO, an aluminum trailer needs aluminum tanks. Our 1987 Avion has 30# tanks, not sure if it came with them, or 40#. I really wish they were 40#, just so they would have that little it more propane onboard.
If I was spending $50K-$110K+ on an Airstream, and maybe $2000 on a hitch, a few hundred on some aluminum propane tanks would be a no-brainer.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-02-2017, 07:10 AM   #8
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
We have a pair of 40# aluminum tanks for sale -- not pretty (one is scratched up) but recently re-certified and with new style valves. Can't see them under the tank cover anyhow. Right now they just take up space, so anyone interested can make an offer.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 09-02-2017, 08:22 AM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Most forklift cylinders are designed to deliver liquid propane to the engine. The pickup is at the bottom of the tank, not the top. They cannot be used for any RV, let alone an Airstream. Some forklift cylinders are designed for vapor service, and could be used for RVs. But configurations vary. When buying forklift cylinders, you have to specify liquid or vapor service, with or without fill valves (not all forklift cylinders are designed to be removed for refilling; some are permanently mounted and filled from a port on the machine), with or without gauges, horizontal or vertical orientation. There is no one standard configuration for forklift cylinders as there is for the recreational propane cylinders.
A W Warn is correct in that respect, as usual.
Old 09-02-2017, 08:48 AM   #10
1981 31' Excella II
New Market , Alabama
If your tanks are under a cover is does not matter what they are made of. I lost my cover in a tornado and have not replaced it. I have the original 1980 aluminum 30# tanks that are painted silver. It is way down on my list of things to worry about. I think the 30# tanks will save you about 7lb per tank. You can also find them used. It will probably cost you $100 per tank to have them inspected and upgraded to OPD valves which is really a down grade since they don't have the float gages on them. You can get a double bung aluminum tank that gives you the gage in one hole and the OPD fill valve in the other.
Perry
Old 09-02-2017, 11:29 AM   #11
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
I wouldn't take anything for my aluminium tanks. I have 9# saving in weight on each 30# bottle. A a local gas dealer they carry them and are cheaper than Vintage.
Streamracer is offline   Reply With Quote
Old 09-02-2017, 12:44 PM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I do have a 30 lb left from my 73 avion, ....$100
Old 09-02-2017, 01:09 PM   #13
1995 34' Limited
1978 23' Safari
Napanee , Ontario
We have a 1995- 34 Classic Limited that has old Non-OPD Worthington 40 # aluminum tank that cannot be re-valved to an OPD valve. The only option that JC gave us was converting to vertical tank that requires a total renovation of the front of our AS. I worked hard for almost a year to maintain the front of our AS and kept the front intact at a price. The tank were costly but no worst than the renovation that JC suggested. Vintage Supply were a great help in keeping our AS in it's original form. We would not trade the non-corrosive nature of our aluminum tanks to any steel tank.
Bas&Wen is offline   Reply With Quote
Old 09-02-2017, 02:32 PM   #14
Nags Head , North Carolina
Perry
IMO it does matter what they are made of depending on where you live. I live on the coast on a barrier island plastic rust's here.
oldsaff is offline   Reply With Quote
Old 09-02-2017, 02:49 PM   #15
Vintage Kin
Fort Worth , Texas
The price of rust negates steel tanks.
Old 09-02-2017, 03:26 PM   #16
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
Horizontal Aluminum tanks
We have a 1994 34 Limited with two 40# aluminum tanks. They do not and cannot be refitted with OPD valves. There is an exemption for such tanks and always carry the exemption notice with us. Only one problem - in Canada there is no such exemption - only in the USA. Normally I get them refilled in the US with no problem. Not sure what experience our US owners have in trying to get theirs filled in Canada? Two years ago I had the tanks recertified in Texas and found they do not stamp them but rather apply a sticker.
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 09-02-2017, 03:47 PM   #17
2004 30' Classic
Hillsborough , New Jersey
I had my two 30 lb. aluminum tanks re-certified at a welding shop last year. For the 2 tanks I paid $54.00 for re-certification and they refilled them both for $64.50.
Wolf146
wolf146 is offline   Reply With Quote
Old 09-02-2017, 04:58 PM   #18
A W Warn's Avatar
2000 25' Safari
Aren't those tanks on your Limited horizontal?
Alan
Old 09-02-2017, 10:22 PM   #19
1990 25' Excella
St Lawrence , Pennsylvania
Could you post the exemption notice for me to review?
rjmaype is offline   Reply With Quote
Old 09-02-2017, 10:32 PM   #20
A W Warn's Avatar
2000 25' Safari
the last article on the page
http://www.nfpa.org/public-education...ention-devices
Alan
Rouge Polish, nay or yay? scottcameron Cleaning, Stripping & Polishing 11 10-30-2016 10:09 AM
Bamboo: yea or nay? Cody Madison Floor Finishes 11 02-10-2015 08:47 PM
A 1976 31' Airstream on Kijii. Yay or Nay LoftyPines Dollars & Cents 6 09-11-2013 10:24 AM
Hey Tundra folk! TRD....Yea or Nay? OldVwHunters Tow Vehicles 8 09-01-2013 06:39 AM
Oh Yea Fun-Lovin General Repair Forum 3 08-24-2003 05:26 AM
