Old 05-10-2021, 03:31 PM   #1
2014 Interstate Ext. Coach
Bennington , New Hampshire
Li-bim
After 4600 miles on the road, I can report that the li-bim (precision circuits inc) works every bit as advertised. Longest stays 84 hours, lowest DoD 24%. Alt charge max 58A or variable, 0A charge at 14.2V. The Li-BIM is an easy change over from LA to Lithium and the chassis/coach battery charging functions as designed, an alternative to DC-DC charging. I do not know the algorithm of the device, however I never noticed any alternator overload or overheating. BTW the 200a LFP battery was only recharged with alternator or solar for the entire trip, no charger
Sailfast is offline   Reply With Quote
Old 05-10-2021, 07:55 PM   #2
Hawk-ination's Avatar
2014 19' International
Cedar Rapids , Iowa
I believe it’s 15 min charging and 15 minutes off. We’ve had good luck so far also. Only issue is I think the wire they said not to connect might have something to do with our rear door locks. I may need to wire it in to make the locks work correctly.
Hawk-ination is offline   Reply With Quote
AI 19 Lithium Conversion BIM csb333 Batteries, Univolts, Converters & Inverters 0 09-06-2020 10:31 AM
Intermittent BIM? Land Stitchy Sprinter and B-van Forum 37 10-05-2018 12:51 PM
BIM Worked Properly Today Boxster1971 Sprinter and B-van Forum 10 01-21-2017 12:14 PM
Interstate charging system - BIM confusion! wayneskid Sprinter and B-van Forum 23 01-17-2017 05:04 PM
BIM question VAtom Sprinter and B-van Forum 6 08-16-2016 06:57 AM
