Originally Posted by KK4YZ
A) yes. The dc/dc converter will act as the “isolator” I referred to in my original reply. It will prevent discharge of the trailer batteries into the TV batteries
B) Given that your existing setup provides little or no charge current to the trailer batteries from the TV, that answer would be “yes” as well. How much charging current will be provided depends on your selection of dc/dc converter, how you configure the dc/dc converter and the wire gages involved.
Your trailer has the incessant side exhaust refrigerator fan that will draw just roughly one amp, most of the time, even during winter. If the Television amplifier or subwoofer is "on" you might accidentally draw more current. I unplug my subwoofer.
Over-charging your tow vehicle batteries from your Lithium batteries or solar charge controller is not a good idea, even if Airstream battery drain isn't catastrophic.
The (almost perfect) 9 amp Victron isolating DC-DC convertor allows you to arrive with batteries topped off. Higher power DC-DC convertors might overload your existing vehicle tow-package wiring and fuses. The voltage drop to the trailer would limit your charge while towing to a trickle even with lower voltage (LA or AGM) batteries. 9A will be a nice improvement.
I recommend mounting the DC-DC in your tow vehicle (rather than inside the trailer) and using the remote enable provided. We use our Airstream 7-pin connector for connection to our portable solar panel. That won't work properly through an isolating convertor.
