Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2000 - 2004 Safari
Old 08-05-2010, 04:42 PM   #1
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
Breaker Panel Location???
As I've been diving into the nitty-gritty of all the systems of my trailer I find coveyhulls that look like walls and are actually hinged doors.
Well, found the water pump, improved the packaging and added a diverter valve for winterizing with antifreeze. Found out that the LP gas detector was not connected, now it is. Found the wire bundle and fuse for the LP gas detector (thanks to an excellent assitance from the AS cust. service.), replaced it.
Now, I'm looking for the breakers for the whole electrical system. The manual says they are where they aren't.
This is a '04 Safari with the twin beds at the rear.
Any insight as to where I can find the fuses, GFIs, etc.
Thank you in advance.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 08-05-2010, 04:53 PM   #2
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
Should be at the foot of the street side bed, or at least they were on my 2006 Safari 25
Greg
Roadtoaster is offline   Reply With Quote
Old 08-05-2010, 08:18 PM   #3
richinny's Avatar
2011 34' Classic
frank, don't forget that the detector might draw power even when in 'store' mode.
Ricky
Old 08-06-2010, 05:56 AM   #4
greatlakes's Avatar
2004 25' Safari
Yes, Ricky, as I found out, the LP detector is hard-wired directly to the batteries via a 1A in-line fuse. That constant current draw is something I'm going to have to live with. BTW, AS could have made that wire bundle a bit more accessible without us having to either crawl way under the couch or removing the couch to get to it. If I gain one more pound I will not be able to reach it! All is well, now I have to find the fuse box.
___________________
Frank
2004 25' Safari
Old 08-06-2010, 12:15 PM   #5
greatlakes's Avatar
2004 25' Safari
Found it!
Roadtoaster,
I found the breaker panel just where you said. Thank you.
___________________
Frank
2004 25' Safari
Old 05-01-2021, 07:23 PM   #6
2013 16' Sport
Petaluma , California
2013 Bambi Sport Breaker location
I have a 2013 Bambi Sport 16 ft. My breaker panel is located across the heater vent under the read bed. It is a black plastic cover. No tools are needed to open it.
Flores415 is offline   Reply With Quote
Breaker Box Location mico75 Electrical - Systems, Generators, Batteries & Solar 1 07-31-2009 03:55 PM
1999 cutter 12v breaker location apetit Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 8 12-28-2004 02:22 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
'90 Land Yacht Breaker Location leomarcotte General Motorhome Topics 1 05-14-2003 03:34 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
