Breaker Panel Location???
As I've been diving into the nitty-gritty of all the systems of my trailer I find coveyhulls that look like walls and are actually hinged doors.
Well, found the water pump, improved the packaging and added a diverter valve for winterizing with antifreeze. Found out that the LP gas detector was not connected, now it is. Found the wire bundle and fuse for the LP gas detector (thanks to an excellent assitance from the AS cust. service.), replaced it.
Now, I'm looking for the breakers for the whole electrical system. The manual says they are where they aren't.
This is a '04 Safari with the twin beds at the rear.
Any insight as to where I can find the fuses, GFIs, etc.
Thank you in advance.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
