Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2000 - 2004 Safari
Old 07-13-2018, 08:54 PM   #1
Deesnestwa's Avatar
2000 25' Safari
St. Augustine , Florida
Battery monitor and charger
I’d like to install a battery monitor and would like to ask for suggestions on which one I should buy. I heard of the Vector? But it is a bit pricey for me. Some I saw were as inexpensive as $18, but was doubtful they would work properly. Does anyone have a monitor they would recommend? I just purchased a Optima AGM 12v battery and next plan to get a charger for it. Suggestions for a charger would be very helpful too. I found that the 2-4 amp models take a very long time to charge. I was hoping for something quicker. Thank you.
Deesnestwa is offline   Reply With Quote
Old 07-13-2018, 09:13 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
As far as the monitor, I went with the Victron 712 and while not cheap it's well worth the cost. The smart phone blutooth feature is great.
Anything in the 10's of $ will only be a voltage readout and while that is better than nothing it's not what a good monitor will provide.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-18-2018, 09:52 PM   #3
Deesnestwa's Avatar
2000 25' Safari
Thank you. I’ll look at that model. Thanks for your help.
Victron Battery Monitor and Blue Sea Battery Switch billrector Batteries, Univolts, Converters & Inverters 6 01-28-2018 02:13 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
