Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1960 - 1965 Safari
Old 11-17-2007, 09:03 PM   #1
Utica , New York
1965/2007 12' Viewpod
Project: Transform a 1965 Safari into a tiny "Viewpod" trailer.
I found the raw material on Craig's list, Plattsburgh, NY. The trailer had already been gutted, saving me some work...
I spoke with Colin, the owner of the lot where the trailer was parked and told him of my plan. He invited me inside his shop to show me his own similar project, half finished. It was quite nice to be able to stand inside a space I had been imagining for the last few months. He generously shared his ideas and techniques with me.
ID:	49459   Click image for larger version
C_Ferguson is offline   Reply With Quote
Old 11-17-2007, 09:10 PM   #2
Utica , New York
Window removal
Since the trailer was almost completely gutted, I started by removing the windows - hoping to sell them and make back some of the initial cost of the trailer. I am planning a rear door, with windows on each side. There are two identical windows that will work for this purpose - they are bit larger than I might have liked, but will make for a nice light filled space - and as good screens for rear-projecting video and images from the interior.
Removing the windows is just a process of carefully drilling out rivets with a 5/32" drill bit. Start the bit as close to the center of the rivet as possible, then continually lean the bit towards the center. The soft aluminum drills easily. Eventually the head falls off and the rivet punches through to the other side.
Old 11-17-2007, 09:19 PM   #3
Utica , New York
Skin removal
The interior skins came out the same way, drilling out rivets. Then the exterior skins. I lifted the endcaps off and set them aside.
ID:	49463   Click image for larger version
Old 11-17-2007, 09:23 PM   #4
Utica , New York
Leftover bits
Aluminum is 55 cents a pound, so I am carefully sorting all the leftover metal for recycling.
I had intended to use the old frame - cut off the last few feet and reposition the axle. The 65, however, has a much deeper and heavier frame than my 62, so I just cut it up with a torch for recycling. Instead, I'll fabricate a new frame from scratch.
ID:	49466   Click image for larger version
Old 11-17-2007, 09:26 PM   #5
Utica , New York
Frame
I am using 3"x2" stock for the frame, it's probably much heavier than necessary, I'll make the next one lighter...
The coupler was still in good shape, so I cleaned it and the jack up to use on the new trailer.
I clamped things together with c-clamps, and went to Tigging.
ID:	49468   Click image for larger version
Old 11-17-2007, 09:31 PM   #6
Utica , New York
Frame
I tacked things together first, to make sure the fit was good. The crosspieces are cut from 14 gauge stock, cut out with a plasma cutter.
ID:	49470   Click image for larger version
Old 11-17-2007, 09:34 PM   #7
Utica , New York
Outriggers
The outriggers were cut on a bandsaw, then shaped on a sander.
ID:	49473   Click image for larger version
Old 11-17-2007, 09:36 PM   #8
Utica , New York
Floor pattern
The c channel will be re-used as well, and here it is used as a pattern for the curves. The floor material is 1/2" douglas fir ply.
ID:	49476   Click image for larger version
Old 11-17-2007, 09:44 PM   #9
Utica , New York
Welding
The frame members are cut with a horizontal bandsaw, the edges cleaned with an angle grinder, pieces clamped together, then tacked.
ID:	49478   Click image for larger version
ID:	49480   Click image for larger version
ID:	49482   Click image for larger version
Old 11-17-2007, 09:56 PM   #10
soldiermedic's Avatar
Florissant , USA
Carlos,
Another project for us all to look forward to. New screen name as well?
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-18-2007, 06:54 PM   #11
Utica , New York
Outrigging
The outriggers are welded on in the same fashion as the crosspieces, clamped, tacked, and welded. The frame was laid out on a piece of plywood to estimate where some extra support outriggers would fit in the front of the trailer. One piece of 3x2" stock was cut in half on the bandsaw to fit in the sloped area at the front of the belly pan. I used a piece of angle iron to find the current balancing point to estimate where the axle should go.
ID:	49531   Click image for larger version
ID:	49533   Click image for larger version
ID:	49535   Click image for larger version
Old 11-22-2007, 03:50 PM   #12
Utica , New York
The frame was sandblasted and washed, then painted with por15. I used lap joints on the floorboards made with a router. The elevator bolts that hold down the floor were countersunk with a forstner bit, then the original C channel was installed on the corners. Some new C channel spans the sides.
ID:	49749   Click image for larger version
ID:	49751   Click image for larger version
Old 11-22-2007, 03:53 PM   #13
Utica , New York
Cones
The two end cones were attached to the frame with clecos.
ID:	49755   Click image for larger version
Old 11-22-2007, 06:14 PM   #14
2333's Avatar
1962 24' Tradewind
Colorado Springs , CO
Wow
I thought this was a photoshop trick, until I read thru the post. I'm sure you'll get a lot of opinions on this making conversion, but either way....it's a lot of work and looks like you're doing it well, and seeing your other work, I am looking forward to the interior.
Craig
2333 is offline   Reply With Quote
Old 11-22-2007, 06:47 PM   #15
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
i am very impressed at your skill and knowledge of working the metal, your trade i assume
very good mosaic you created in photoshop for getting the idea across. how's your cad skills?
elbundi is offline   Reply With Quote
Old 11-22-2007, 07:02 PM   #16
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
This is way cool!
Next year, in October, we are having our Washington DC WBCCI Unit Installation Rally down here in Norwich, NY. You need to attend with this very cool project. Will you be done by then? We might be having a Forums Rally here around the Sherburne Pageant of Bands June 5-8 here as well. What do you have envisioned for Interiors.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 11-22-2007, 07:25 PM   #17
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Carlos -
Beautiful work as usual. Is the wheel well going to end up in the door area, or will it be in the aft end piece? From your balancing act, it appears that you'll have to move a few outriggers, but I couldn't match that picture up with the "shell on" picture to see exactly where that was
On edit: I forgot you already mentioned that this is going to be a rear entry Carry on with the cool project.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 11-22-2007, 07:36 PM   #18
Utica , New York
Originally Posted by GreatPumpkin
Carlos -
As far as the axle goes, I'm not sure yet where it should go (and am waiting 'til next week for it to arrive). I think I will get this top part more or less done, then find the balance point, then take the top off (it's pretty light), remove the center piece of plywood, flip over the frame and put the axle on the easy way, attach the last two outriggers, put on the belly pan, flip it again and put the top back on... I'll have a better idea where to put it on the next one I suppose without the extra hour or two of take off and put on. I'm guessing the axle will be centered more or less at the leading edge of the rear cone.
Old 11-22-2007, 07:37 PM   #19
Utica , New York
I keep meaning to learn cad but never get around to it...
Old 11-22-2007, 07:40 PM   #20
Utica , New York
Rob
I'm still thinking on the interior... maybe some industrial linoleum on the floor, or tiles of plywood...
keep me updated on the rally.
Almost done with our 1965 Caravel toastie Member Introductions 32 08-27-2020 12:43 PM
A/C for a 1965 Caravel toastie Furnaces, Heaters, Fireplaces & Air Conditioning 10 07-14-2019 01:30 PM
the BEST forum rally of the year...2007 2airishuman Community Polls 32 12-30-2007 08:55 PM
1965 Avion L David Member Introductions 4 07-13-2006 08:43 PM
1965 safari Gllj05 Member Introductions 5 05-29-2006 06:53 AM
