07-10-2015, 07:46 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
can this spring be welded
found my main awning spring to be broken. Can it be welded?
AIR #13
07-10-2015, 07:50 PM
1978 Argosy 24
MooreHaven
Generally speaking springs should not be welded,as the heat can take the temper out of the metal in the area of the weld.
This is only temporary unless it works! Red Green
07-10-2015, 07:55 PM
1973 21' Globetrotter
Houston
Technically, yes, but practically, no. Most of what makes a spring a spring is the composition of the steel, the hardness it is hardened to, and the temper that it is drawn back to. The act of welding is going to wreck the hardening and temper in the area of the weld.
Does it hurt to try? Probably not--what the heck it might last another 20 years and work (almost) as intended.
1981 31' Excella II
New Market
No it can't be welded and it would crack again somewhere else. Get a new one from the awning manufacture.
Perry
07-10-2015, 07:57 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
You can weld it, but it will never work correctly afterward. The heat will take the "spring" out. Then it will not be very long till it breaks again when it flexes.
Alan
07-10-2015, 08:18 PM
Huh?
1975 27' Overlander
Twin Cities
You can not weld a spring.
I am a good welder and wouldn't even bother trying to weld that.
07-10-2015, 08:32 PM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
Good metal prep, at least one full overlap wrap, lowest heat / amps for good penetration, file down the rough spots, and give it a try. It can be done. Let us know....
You cant weld suspension springs, leaf or coil, extension or compression. But a low tension torsion spring can.
07-10-2015, 09:49 PM
1988 Argosy 32
Lomita
Is that from the sun shade roller ?. git a new one if you can.
07-11-2015, 02:07 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I imagine that spring would be so apt to "blowing out" that it would look like a sparkler when the arc is struck,,, and even if a weld could be made it would be brittle beyond belief in the heat affected zone...
And besides, if the spring broke in one spot, even if by some miracle it is effectively welded, it will break somewhere else in short order.
07-11-2015, 04:46 AM
Airstream Driver
1994 30' Excella
Austin
Thanks everyone for the replies and expertise!
Its a Zip Dee awning and the springs are readily available
http://www.awningsbyzipdee.com/media...36ffffd502.pdf
AIR #13
