Old 11-29-2020, 10:42 AM   #1
Magnet18's Avatar
Churubusco , Indiana
Classic motorhome alternator pulley
OK, I have been digging at this for awhile and not gotten anywhere. Like many with 80s classic motorhomes and 454 engines, my alternator pulley squeaks. I know from records the alternator was replaced in 2011, and the squeak seems to be from the replacement pulley that comes with most alternators being close enough to work, but slightly different.
WayneG at one point mentioned this
"I also found out that when I changed an alternator a few years earlier, I should have saved the original pulley because the one that came with the new alternator did not have the proper dimensions. I had to find a old style pulley at an alternator shop, no more slippage with this belt and original pulley."
It is assumed that this slippage contributes to heat in the alternator and causes premature failure.
The correct belt is 11A1255 or 11A1195 (depending on length for emissions accessories)
I've been trying to locate the correct pulley online but I have not had luck finding the part number, nor do I have an "alternator shop" that I frequent. There might be a rebuild shop in my city up to the job but I know nothing about them and it might be a potshot.
Anyone know the correct part number? I would like to just get this pulley swapped out while I'm digging around installing the TBI system in the next couple weeks.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 11-30-2020, 08:55 AM   #2
Rob,
This makes for an interesting topic. I wonder how many rigs even have their original pulleys anymore. When buying a replacement alternator at a parts store they generally come with pulleys and I wonder just how many people actually verify the new pulley matches the old pulley.
Several coaches that I've owned over the years definitely didn't have the original alternators installed when I owned them and it wouldn't surprise me a bit if the pulleys were the wrong size.
On my Argosy I installed an alternator that originally had a ribbed belt pulley on it so I swapped it out for a pulley that I "estimated" to be the right diameter and belt width. I wouldn't be a bit surprised if mine was not the correct size.
1975 24' Argosy Motor Home
Old 12-01-2020, 08:38 AM   #3
Magnet18's Avatar
Yep! I'm less worried about diameter, I just want to stop the darn squeaking.
I saw a recent post about making sure it's aligned properly, will give that a check as well
-Rob
Old 12-06-2020, 05:12 PM   #4
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I had a heck of a time with alternator belts. I finely was able to put a straight edge across the pulley only to find that the alternator was way out of line with the belt. Went to the old style alternator bracket and the problem went away.
choctawmel is offline   Reply With Quote
Old 01-26-2021, 10:27 AM   #5
Magnet18's Avatar
Any info on what that bracket part number might be? I think I have exactly the same thing happening. Alternator starts squealing like the dickens the instant I hit 3000 rpm
Old 01-26-2021, 10:35 AM   #6
Originally Posted by Magnet18 View Post
...Alternator starts squealing like the dickens the instant I hit 3000 rpm
That's an easy fix.....stop driving at 3000 rpm......
Old 01-26-2021, 11:18 AM   #7
Magnet18's Avatar
Thankfully I have the GVOD, keeps it right at 2600 when cruising along
I'd still rather be able to hit the gas without waking the dead
Pulley/block for awning? RankAm Awnings 3 10-15-2017 06:24 PM
Alternator rating - 1981 Excella 28' Motorhome xengineer Mechanics Corner - Engines, Transmission & More... 3 06-19-2010 08:07 PM
Alternator ID for 1982 Excella 28' Motorhome xengineer Mechanics Corner - Engines, Transmission & More... 3 09-15-2009 10:53 AM
1983 Airstream 310 Motorhome Alternator Needed scotdo Mechanics Corner - Engines, Transmission & More... 1 04-14-2008 09:47 PM
