I too had a problem with the shower door being too low, thus tearing the seal off the door bottom.
I bought a 3/8" nylon bushing at the hardware department.
I inserted it under the hinge end of the door. I used a self tapping screw to hold it in place.
Attached is a sidewise pic
2012 25' FB International
Trent Woods
I might have to do that also as I need to replace the seal. Did you need to remove the door to do that or does the bushing just rest under the door? I do not get how you installed the bushing. Thanks
Larry
I left the door on. I just raised the door up and inserted the vinyl bushing.
I installed the self tapping screw simply to hold the bushing in place.
After this was done I inserted the vinyl seal.
