Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 05-22-2015, 10:25 AM   #1
1954 25' Cruiser
Cody , Wyoming
Bath conversion
We are renovating our 1954 Cruiser 25'. It currently has back bed with mid wet bath. I want to move the bath to the rear ( to include shower) and put two twins in the middle. Has anyone done this? Will the full bath fit in the end cap area? Windows start right after the end cap. What should I do? Thanks for any help!
jtfink is offline   Reply With Quote
Old 05-22-2015, 10:46 AM   #2
JimGolden's Avatar
1977 31' Excella 500
I had started to but then sold the trailer and bought one in the floor plan I really wanted. You will probably need to move the tanks around. And you may run into problems with the rear being a lot heavier than OEM and could cause frame issues. But if you're tearing it down to the frame anyway, now is the time to beef it up so that you don't have problems on down the road.
If you need to move a window, that is some work, but it's really nothing more than cutting and riveting.
But anyway, probably the hardest thing about doing this swap will be the plumbing for it. If you can handle that, then it's not that big a deal.
I'd personally consider making a totally new frame and just reusing the shell. But it could be done with the original one too.
Best of luck. Should be a neat project,
- Jim
JimGolden is offline   Reply With Quote
Old 05-27-2015, 07:07 PM   #3
1954 25' Cruiser
Cody , Wyoming
Bump
Rear bath to Center Conversion Harrysheets General Interior Topics 4 09-26-2012 10:31 PM
Rear Bath to Bed conversion birdy General Repair Forum 2 07-18-2010 06:22 AM
want to trade center bath for rear bath? nomader General Repair Forum 7 02-23-2010 05:40 PM
Move a rear bath to a side bath? rjacques General Repair Forum 11 12-27-2008 10:25 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
