Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 04-30-2017, 04:37 PM   #1
2017 27' Flying Cloud
Lake Forest , Illinois
Q on GFCI outlet
Is there any specific reason why the 2017 FC 27ft FB has a single GFCI (and for that matter, inverter) outlet supplying power to the TV in the sitting area? Is there any reason why I should not replace with a double outlet - all the other outlets in the unit are double.... thanks for your help...
kjbishop2 is offline   Reply With Quote
Old 05-01-2017, 02:41 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
There are a number of posts on this subject and some informed sources have indicated that Airstream was trying to be sure that you did not plug in more than the circuit can handle. You can replace the outlet with an RV model of the two outlet or you can just grind out the second outlet holes with a dremel tool.
Larry
lsbrodsky is offline   Reply With Quote
GFCI Shore Power Outlet Trips JRF0st3r Electrical - Systems, Generators, Batteries & Solar 12 06-20-2012 11:24 AM
Upgrade for external GFCI outlet dznf0g Electrical - Systems, Generators, Batteries & Solar 3 12-21-2011 09:24 PM
gfci help quiksilver Lights - Interior & Exterior 2 06-07-2007 08:50 PM
Gfci achip Electrical - Systems, Generators, Batteries & Solar 4 07-22-2006 11:52 AM
Gfci jcf48 Electrical - Systems, Generators, Batteries & Solar 0 07-21-2006 11:00 AM
