Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 10-17-2017, 09:44 AM   #1
2018 25' Flying Cloud
St. Paul , Minnesota
Can I tow without the batteries?
I store my batteries at home in the winter connected to trickle chargers. I store the trailer at a different location. I'd like to take the batteries out while at home, then tow to the storage site.
Is this safe? Will the AS exterior lights (brake, etc) work when hooked to the 7pin connector on tow vehicle, but has no batteries?
rothse99 is offline   Reply With Quote
Old 10-17-2017, 09:52 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not 100% sure on a 2016, but on my trailers all your running lights will work off the tow vehicle, the brake lights will work, but you will not have any trailer brakes if the trailer disconnects.
Old 10-17-2017, 09:53 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The lights and brakes work from the TV via the trailer umbilical cable. The brakes will not work if the trailer disconnects from the TV and the cable is pulled out. The trailer disconnect switch requires an on board battery to function.
Richard
Towing without batteries Patti G. Batteries, Univolts, Converters & Inverters 4 03-09-2017 09:46 AM
12v without batteries Sirwalshalot Electrical - Systems, Generators, Batteries & Solar 10 12-08-2016 11:01 AM
Can I tow my 25ft Safari without using my Prodigy Brake Controller? Blockstream Brakes & Brake Controllers 8 07-05-2014 06:27 AM
Storing Trailer Without Batteries greatlakes Batteries, Univolts, Converters & Inverters 6 04-24-2011 12:23 PM
Trailer Use Without Batteries . poorboycjs Electrical - Systems, Generators, Batteries & Solar 1 05-27-2004 04:52 AM
