Sounds like you have a couple of different issues.
1) When a water pump continues to keep running, it either means you have a leak, or the pump head is not able to maintain pressure, so it keeps running.
2) The coach lights will momentarily dim as the pump turns on, as it does draw quite a bit of energy. The only way to circumvent this would be to wire the pump directly to the coach batteries, instead of through the fuse block that the coach lights are hooked into as well.
Cheers
Sidekick Tony
