11-13-2014, 10:32 PM
Chapel Hill
, North Carolina
Where is the water pump? - 2014 Bunkhouse 30'
I am winterizing for the first time. Followed the directions all the way through to hooking up the bypass hose for the RV winterizing fluid to pump into the lines, but can not find the water pump. The manual says under the roadside wardrobe behind a pressure latch. Short of climbing under the trailer, I have not located it. Thanks.
11-15-2014, 09:01 AM
Chapel Hill
, North Carolina
The answer is according to Airstream support - pull out the bottom three shelves between the lavatory and the oven.
So in case anyone from airstream reads this, here's a little suggestion.
Either
A. make it possible for someone to permanently add a T bypass (all of 3 inches long), or
B. Spend the 50 cents or buck at your volumes and put in a T bypass during construction. It really makes no sense to me why this is an owner-added option given how critical it is to winterize in almost all areas where Airstream is sold.
As is, the bolting down of the water lines to the floor essentially precludes adding a permanent T bypass. The tie downs do not allow the hose to move back far enough to get the 3 inch T bypass valve in place. The tie downs are screwed down such that they are next to impossible to unscrew due to their location and close quarters. So, what should really be a factory installed component ends up taking hours to do or in my situation I will have to take apart the input line coupling, screw in the T, winterize, remove the T, hookup the input line again, and then repeat the entire process next year. Sort of like having to take a transmission out of a car to change the antifreeze.
Common, important maintenance items should be relatively simple to do.
11-15-2014, 09:22 AM
2019 27' Globetrotter
Missouri Valley
, Iowa
Steve, I understand completely your frustration. I winterized my '14 Interstate last weekend and had a similar problem. On my water pump there are QuikTach connections for both sides of the pump. The inlet side is the most difficult to get to with what appears to be a 3/4" or 1" vinyl braided hose. Putting in a T to enable AF suction will be quite a chore. I was able to blow all the water out with my air compressor but like to put AF in the system as well. Guess I have a project for next summer.
Dan
11-16-2014, 10:28 AM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Steve, Surely what you describe is not correct. That sounds absolutely ludicrous.
Why is the bypass not standard? On my 2012 25'FB I was very much surprised to learn the bypass kit was not installed and that I had to do it myself and that the bypass kit had to be installed under the fridge which was a royal pain. I then put a 5 gallon soft tank in the closet so I could winterize quickly on our back and forth trips to Phoenix during the winter.
Does the factory expect you to blow it out with low pressure high volume air every time or do they expect you to take it to the dealer every time? I need to lug around a big air compressor every time I leave warm to head back to cold Denver. Really!
I am more than a bit disappointed in the thoughts of dealing with this again on our new forth coming 30' Bunk. Well, I have not picked it up yet and will talk to the dealer about having it installed with a length of hose that will allow me to reach a larger 5 gallon soft tank.
Still you have to remove drawers and get back in there to work the valve each time. Why is there not an access door maybe in the bathroom or better yet from outside.
I still holding out that the 2015 will not be the pain the 2012 was but it is not looking good.
11-16-2014, 02:01 PM
Chapel Hill
, North Carolina
The warm air duct is below the bottom drawer and it does pop out, BUT the air duct hosing has no play and you really can't pull the air duct panel away much to do work. I believe there would be enough room to get your hand in, pull out the hose and turn on the bypass. Still, it will be a royal pain even for the dealer to install. I personally if I were ordering one, would insist that the factory put it in. For them, it would be trivial.
For me, I just left the input from the tank loose, sucked in the fluid, then removed the t and hooked back up the tank feed to the pump.
Good luck.
11-17-2014, 03:26 PM
2013 30' Classic
Greenwood
, Mississippi
I had to have the dealer install a winterizing T, valve, and tubing. It is in the wardrobe under a false floor on my trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-21-2014, 05:33 PM
2015 30' FB FC Bunk
Golden
On my 2015 remove the drawer above the bottom vent cover just to the right of the bathroom door. Then remove the vent cover, pull forward just a bit, turn sideways and tuck it up into the area where the drawer was. Remove the feed hose attached to the pump filter. Then remove the pump filter assembly from the pump. Install the bypass valve kit, reattached the feed hose to the valve and then reinstall the pump filter assembly to the pump. For the life of me I don't know why they don't install one from the factory.
01-05-2015, 08:25 AM
Miller Place
, New York
Shame on Airstream for not including a $10 Tvalve on the intake side of the water pump to facilitate winterizing. They are such a "class" company in so many other ways, including the price of their products. I hope they have a full-time "net" person who reads these forums.
01-05-2015, 08:50 AM
Salem
, Oregon
Hi, and that huge hole where the drain pipe goes through the floor is an easy access for Mickey Mouse to get into your trailer. Ask me how I know this?
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
