04-12-2016, 10:41 PM
#741
Washington
, Missouri
Originally Posted by OTRA15
Of course, Bob, I guess one could leave the duct tape in place, eh, and end up with
CruizinDuctsTape?
Let us know what you find on your unit . . .
https://www.duckbrand.com/products/duck-tape/colors
what else would one expect...green, yellow and of course tie dye
and I just noticed...glow in the dark
also available in shelf paper for the RV
will do on the eval
04-13-2016, 02:31 AM
#742
Sag Harbor
, New York
04-13-2016, 03:09 AM
#743
Sag Harbor
, New York
Originally Posted by VinnyBoomer
Arizona, take off your rainbow shades
Arizona, have another look at the world
My myyy
Arizona, cut off your Indian braids
Arizona, hey won'tcha go my way
Thanks for the updates. Glad the trip is working out (Comfort Zone thread) -- don't forget you can always ask here about FC20 problems.
Happy Trails!
Peter
04-13-2016, 07:47 PM
#744
2019 25' International
Traverse City
, Michigan
My myyy
Mark Lindsay
"Don't let perfect be the enemy of better."
04-13-2016, 08:27 PM
#745
Washington
, Missouri
Thinking I need to make a spin thru [ More]
love the band
04-15-2016, 07:59 AM
#746
Sag Harbor
, New York
Summerization summarization on the OTRA Music Channel I thread, plus a great song for the road/sky in an Airstream with wings -- From a Window Seat by the LA group Dawes.
Let the Summer Games begin!
04-16-2016, 02:58 PM
#747
Traverse City
, Michigan
You guys are seriously off topic!
04-17-2016, 05:25 PM
#748
Sag Harbor
, New York
Your comment is noted.
04-17-2016, 07:49 PM
#749
Washington
, Missouri
ditto.
b
04-19-2016, 07:47 PM
#750
Traverse City
, Michigan
04-20-2016, 06:41 AM
#751
Sag Harbor
, New York
Actually Darrell we have been busy with the birth of our fourth grandson last week. Your point about being off-topic was well taken (if a little aggressive in tone IMO). I hope to finish the wheel well work this week to cover the exposed plywood sub-floor. Hope your recent rally put you in a good Springtime mood . . .
Peter
04-20-2016, 06:50 PM
#752
2015 20' Flying Cloud
Eagle River
, Alaska
Just ordered 3x 16'' Sendel Rims and Michelin LTX M/S 2... we'd rather mitigate any issues on our move to Alaska this summer and beyond! We can't wait to get out on the road!!
04-21-2016, 10:00 AM
#753
Traverse City
, Michigan
Peter
Sorry, my comment was meant totally tongue-in-cheek! I love it when you guys talk about music!
04-21-2016, 10:12 AM
#754
2016 23' International
Centennial
Good Morning 20 Footer Folks.....I am getting ready to go camping and need some help.
I have found the following:
1. Water heater bypass valve (yellow)
2. A valve on the white (assume cold) water line next to the water heater
3. Can't find a valve for the red (assume hot) water line next to the water heater......anyone know where it is?
4. Two valves for hot and cold (drains) in the rear storage compartment.
Are there any other valves I need to look for before connecting water to the Airstream? The Owners' manual says there is one under the trailer.....darned if I can find it
Steve "Centennial Man"
04-21-2016, 11:11 AM
#755
Sag Harbor
, New York
Hi Steve,
Good news that you are getting ready to go camping!
Bob [CruizinDux] posted some photos of the two low-point drains under the front dinette seat.
One of the drains is fairly visible (your 2), and the other is buried under that box on the back of the heater (your 3).
Bob's photos in Post 408: http://www.airforums.com/forums/f516...ml#post1718573
My photos in Post 411: http://www.airforums.com/forums/f516...ml#post1719109
The right-hand valve, as seen in my photos above, is hard to see when you look down through the opening in the dinette seat base.
Post 428 has a photo from above, and the hidden valve is slightly shown under that dark box on the back of the water heater:
http://www.airforums.com/forums/f516...ml#post1721787
They are also hard to turn, so a small adjustable wrench or pair of pliers helped me get them started.
The other valve you need to close is the white (yours may be brass?) one for draining the fresh water tank. If you stand at the street side of the trailer, facing the sewer dump valves and outlet, the water tank drain valve is just behind (further toward the center line of the trailer), and is on the vertical face of that large rectangular shape under the rear of the trailer (which protects the actual tank IMO). Your owners manual should illustrate some of this.
Good luck!
Peter
04-21-2016, 11:31 AM
#756
Sag Harbor
, New York
Thank you for the clarification, but . . .
It has been my experience on the Internet that sarcasm and tongue-in-cheek comments do not translate well, generally speaking. Some authors follow such comments with an icon to warn that the words do not carry their "straight-up" meanings.
If the reader does not "get it" then the attempted humor backfires, as here. I appreciate the clarification.
04-21-2016, 11:51 AM
#757
Centennial
Thanks Peter! I knew there had to be another one accessible from somewhere on the outside. I will look for it this evening. I think I can feel one under the box by the water heater....couldn't get it to turn.
04-21-2016, 12:35 PM
#758
Sag Harbor
, New York
On the stubborn low point drain by the water heater, if you have the "T" valve handle like mine (not round like Bob's), the end of the handle is probably facing forward when open (to the right as you look down at the back of the water heater). You should be able to get a small adjustable wrench on it to at least get it started. Or maybe some small needle-nose pliers? I forget what I used.
Once you break the plastic-to-plastic friction on the new valve, it moves fairly well. Mine had to rotate clock-wise 90 degrees to close, which means the end of the T-handle ended up facing toward the center of the trailer, away from the water heater, when closed. In my photo linked recently, it is the white end of this handle you can just barely see sticking out under the black box behind the water heater.
YMMV
04-21-2016, 01:06 PM
#759
Centennial
Thanks YMMV - I suspect that it's open then, I can't see anything sticking out and can barely get my hand down where it's at. I will try the 90 degree turn clockwise and see what I can do. If it's open, like I suspect, then it would close when I turn it the 90 degrees.
04-21-2016, 01:20 PM
#760
Sag Harbor
, New York
If you bought the FC20 new, then all the valves (low point and water tank drain) should be open, as winterized by the factory/dealer IMO.
You could always hook up the water and see where the big leaks are . . . !
