Old 01-23-2011, 05:27 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Gotta a small leak...FB pana Window
I noticed a week ago while it was raining I had a little water on the seam with green mold, on the bottom seam insid the window. It is not condensation, all the other windows seals are clean and dry.
I'm still under warranty and gonna taker her to get fixed. Anything i should do before and after I taker her in?
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 01-23-2011, 05:29 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
You can look around to see if any other little items need help, you can save several trips that way.
Old 01-02-2012, 11:47 AM   #3
Niagara2011's Avatar
2011 28' International
San diego , California
We just took ours to get some warranty work and they suggested to make a laundry list of anything that might need fixing. I would request they treat the corrosion (if u have it by the tail lights) just to get it documented. Then after they fix it, double check their work (we learned this from experience).
Niagara2011 is offline   Reply With Quote
Old 01-02-2012, 05:42 PM   #4
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Thanks..new street side front pano this week..
My warranty runs out at the and of this month.....kinda a relief in a way!
Shane
TAC ID TX-1432
Old 01-02-2012, 06:58 PM   #5
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Even though we want to put the new ones under shelter (if we have it) I have realized exposing your AS to as much rain, snow, water, and other elements is the way to go. Might as well find those leaks and weak spots while it's under warranty.
Take the long way home
Fly at Night is offline   Reply With Quote
Old 01-02-2012, 07:35 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
I don't doubt that the pano windows were originally built quite leak-proof. I've experienced rain leaks over the front windows twice and had to dig out caulk on the rail for the rockguards over the front windows. Do a thorough job removing the old caulk and then reseal with Sikaflex or Vulkem. Mask with tape to control the mess and then press and smear it in as well as you can. I haven't had to remove the rockguard rail yet and have succeeded with that.
I store under cover and still get this. The ultimate wisdom is, "They all leak."
As nickcrowhurst says, "The price of freedom is eternal maintenance."
5 meter Langford Nahanni
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
1950 Flying Cloud Needs Window Replacement happy123 Windows, Doors, Locks & Vents 2 01-10-2011 05:56 PM
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
