12-22-2013, 07:58 AM
2014 30' Flying Cloud
Ponce Inlet
Two Weeks New
After a long wait we picked up our new 30’ flying cloud two weeks ago and are on a month long+ shakedown cruise. I was very skeptical of driving a 40+ foot rig but so far so good. I have back in twice on the second try both times and me and the wife are still speaking.
The first couple of days we stayed near Ft Meyers transferred all the stuff we could carry in our TV and began the what goes where drill and figuring how all the stuff works. Then it was off to see Lew in Naples FL for AM solar, Isotherm 195 marine fridge installation and continuing AS education.
Next stopped by Daytona Beach (home) to dump the empty boxes and take on more ballast. Finally done with the major modifications and logistic stuff and off for some real camping or is that glamping. We spent the next few days at Fort Clinch SP just north of Jacksonville. Nice campground. Now in Atlanta visiting relatives for Xmas. 6 days off the grid will test the new solar set up. Then its back on the road again. Our plan it to be half timers.
Many thanks to the contributors on this board the information helped us decide what options to add and about how much is fair price. Hope to be able to add some info as well.
12-22-2013, 08:04 AM
Central
, Mississippi
A month long shake down? COOL! Are you swapping the fridge out?
12-22-2013, 08:38 AM
Ponce Inlet
Already swapped out with Isotherm Cruise 195 .
12-22-2013, 08:51 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Congratulations on the new baby! May you have many great Airstream adventures.
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-22-2013, 05:29 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
I would like to read the details about the AM solar system you installed. I am contemplating hopefully 600 watts in panels, four lifeline 300 amp hour batteries and a Magnum 2800 watt box in the middle to manage the system.
12-23-2013, 02:37 PM
Ponce Inlet
AM solar system:
SunRunner Signature 40/4/Pro Core
4 GS 135W solar panels
Magnum 1000W Charger/Inverter
4 Lifeline 6 CT Batteries
New low profile vent covers
Combiner box
Wiring and installation hardware
The wiring is sized for up to 800W should I want to add panels in the future.
The batteries, inverter and solar charger are installed under the couch.
With my FC 30’ 2 AC configuration the 135’s had to be installed lengthwise. There is room for one more 135W and a 100W panel if I need it.
I purchased the system w/ installation from an AS forum member.
The installation required NO additional holes in the shell or belly pan of the AS. SWEET !
12-23-2013, 06:13 PM
2007 25' International CCD FB
Northridge
How does the new fridge compare with the one Airstream provides? Advantages/Disadvantages.
LilNomad
12-26-2013, 07:17 PM
Ponce Inlet
LilNomad
We only had the AS Dometic fridge for 2 days before I swapped it out. So the info is based on my rationale for the swap.
Pros
Energy efficient
Separate compressors for fridge and freezer can get desired temp in both or can turn off freezer if I need to conserve battery or have limited power (15 amp service)
No worries about pre cooling food.
Food always cold
No propane required
Very unlikely to catch fire
Cons:
Cost, although you can get less costly unit with single compressor
Need solar or generator if boondocking.
Based on our experience to date with our solar setup we should be able to run a minimum of 3-4 days with little or no sun. depending on the outside temp.
12-27-2013, 01:18 AM
1978 28' Ambassador
Morada
Looks like a great rig with your initial mods...
Question - Where/how did you mount that 360 lbs battery bank?
I would image the batteries mounted on their 'sides' for clearance - do you think the battery bank weight affected the trailer's for/aft balance or tongue weight to any degree..?
Ray & Pat; Morada, CA
12-27-2013, 07:53 AM
2014 31' Classic
Apache Junction
Removing the 100 pounds of factory batteries for the four nearly 100 pounds each Life Line batteries would have an impact on increasing the tongue weight. The installation from photos put the batteries behind the front wall inside the coach, so the weight downward force vector is several feet closer to the trailer wheels than the original battery location. The increase of around 300 pounds of batteries exclusive of the heavier copper wiring would not all be as tongue weight.
Putting the trailer on some CAT scales will give the result of the entire solar system and heavier fridge installation on the empty weight of the trailer.
12-28-2013, 09:30 AM
Ponce Inlet
The batteries are installed on their side. Switz is correct about 100 lbs of battery removed. Install leaves no storage room under the couch. That probably means at least another 100lbs knowing my DW. The marine refrigerator is within 20 lbs of the original. So overall is pretty close to a wash. There are limited battery bank installation options. We considered install under the dinette but 300 lbs on one side not a good idea. I did not get to the cat scales before the mod so there is no baseline weight. We are still learning and lovin life on the shake down cruise.
Sent from my VS840 4G using Airstream Forums mobile app
12-28-2013, 10:21 AM
2006 25' Safari
St. Augustine
Very nice Beach Bum. That fridge looks nice. Did you sell your fridge while in Naples? Reason is I saw one advertised that said new $600. I just bought a Dometic New Generations just before that sale- too bad. Congratulations on your trip. Perhaps we will meet some time. Happy Camping.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
12-28-2013, 04:08 PM
2013 25' Flying Cloud
Cat City
Half timing! I'm jealous. Good luck out there!
12-28-2013, 07:35 PM
Ponce Inlet
Fridge is still for sale. Love the fridge. Trip is going well although it's raining here southern GA. Good news is no visible leaks
12-28-2013, 08:49 PM
1999 34' Excella
Hillsboro
Pics of battery install? Congrats on successful start!
Peace and Blessings..
Channing
WBCCI# 30676
01-05-2014, 01:16 PM
Ponce Inlet
Pic attached. Wish I could take credit for the installation … Its Lewster designed and installed.
The aluminum baseboard conduit he uses in the exposed areas looks better than the factory stuff. I attached a pic of the wire run under the dinette table and into the bench seat.
We have been out about four weeks now and are very happy with the performance of the system.
