Old 09-10-2016, 11:59 AM   #1
okgypsy's Avatar
1966 20' Globetrotter
lexington , Oklahoma
Help!
Purchased "Agnus" and she is just full of holes... Any recommendations or suggestions? Need to patch the hole and replace cover but I'm not sure what it's called to look for it?? shown here... Click image for larger version
Name:	ImageUploadedByAirstream Forums1473530335.701499.jpg
okgypsy is offline   Reply With Quote
Old 09-10-2016, 12:14 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Some creative food for thought here:
http://www.airforums.com/forums/f381...hes-68104.html
Old 09-10-2016, 12:17 PM   #3
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
I respectfully suggest you'll get more responses if you give a little more information and maybe even better pictures. That top hole could be a hole for an electric plug or who knows what. As to the bottom - is it for a fridge? Do you just need an access door? If you give a model and year of Airstream, folks can better understand what you seeing and asking.
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Old 09-10-2016, 12:51 PM   #4
okgypsy's Avatar
Name:	ImageUploadedByAirstream Forums1473533477.135444.jpg
ID:	271387Click image for larger version
Name:	ImageUploadedByAirstream Forums1473533493.867764.jpg
Old 09-10-2016, 12:52 PM   #5
okgypsy's Avatar
What would I look for on this piece? Not sure what it's called? Click image for larger version
Name:	ImageUploadedByAirstream Forums1473533563.861563.jpg
Old 09-10-2016, 01:02 PM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Originally Posted by okgypsy View Post
What would I look for on this piece? Not sure what it's called? Attachment 271389
Behind the piece of metal it looks like the water heater. It is a fire hazard. Don't try to turn on the water heater until you get a proper door or replace the water heater.
Alan
Old 09-10-2016, 01:11 PM   #7
A W Warn's Avatar
2000 25' Safari
The round hole looks like someone has in the past had a stove for heating. To me it looks like were the flue came through the wall. This is not a normal place for a hole in your trailer.
Since your photos do not let us see which side of the trailer the holes are on or which end is the front, it is difficult to give advice. I'll guess that square hole is were the furnace was removed.
Those lights that can be seen through the window are not original to your trailer. All lighting was originally 12v. Those lights appear to be 120v.
My advice is to get someone who has experience to help you evaluate the cost of renovating that trailer, before you go further. You are looking at big $.
Alan
Old 09-10-2016, 01:42 PM   #8
okgypsy's Avatar
Thanks!
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
