08-04-2009, 08:26 PM
1978 25' Tradewind
Blaine
Door to Nowhere?
We have a '78 Tradewind (2 dbls... front double is pull-out, not booth style)
There is an exterior compartment door which seems to be a door to nowhere.
It opens and what we see is the outside of the interior vinyl wall covering. It is located on the street side, just in front of where the kitchen is on the inside. Right next to the furnace. Basically the wall behind the pullout table. You cannot access the interior via this opening.
The exterior door doesn't close fully and I suspect water will get in. (We've had the trailer for just a few weeks.)
1) What is the door? A feature pertaining to some other model than ours? Or something more useful than we've perceived?
2) Would I kick myself it I just silicone caulked it shut?
(Extra facts for the humor value: it was a funny moment... we struggled to figure which key opened it... then realized that it was tough to open because of, not a *lock* issue, but because of some rigging up by the PO involving duct tape and wedging... then the grand moment of opening revealed: Nothing. A wall. Stunned silence, then uproarious giggles)
Now, what to do? To caulk or not to caulk?
By the bay
08-04-2009, 08:30 PM
Retired.
, At Large
From your description, it sounds like either a PO was going to add a door, and never finished it, or the door is supposed to be there, and a modification inside caused it to go nowhere. Can you post a picture?
Also, silicone is contraindicated on aluminum, it contains ingredients known to the Airstream community to cause bad stuff to happen to the aluminum.
08-04-2009, 08:35 PM
Montreal
, Quebec
Hello, thats kind of funny...we just installed a door which leads to nowhere on our recent Airstream. When we bought it, it had a sliced main side panel close to the rear and made more sense to install a door than replace the main side panel. Could have been the same reasoning from your previous owner.
08-05-2009, 09:03 AM
1978 25' Tradewind
Blaine
Ok,
total newbie here thinking I could use silicone caulk... thanks for gently telling me NO (when it is probably discussed so often)
I see now that Vulkem is for the aluminium. (So much to learn!)
It'll be a week before I can have the time to open the door-to-nowhere again for a pic.
After learning about Vulkem by reading in the archives, I'm still left with this question about that product:
Where can I buy the Vulkem?
Many thanks for your info
08-05-2009, 09:37 AM
St. Cloud
I'm not sure if they're all butyl caulks. But my preference is Sikaflex 221. It develops a dry surface skin in half a day compared with Vulkem which seems to take a long time. Gray is an excellent match for your favorite color.
https://store.airstream.com/index.php?cPath=44&page=2
08-05-2009, 01:57 PM
1966 24' Tradewind
Oak View
I like having a door that goes nowhere, it keeps me from going through and getting lost...
Repeat stunned silence, then giggles...
08-05-2009, 02:50 PM
1978 31' Excella 500
Genoa
, Nevada
Assuming you didn't come out of that door first.....
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
08-05-2009, 02:57 PM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Before you seal it up...
Place a treasure map or photo of Rod Serling in there
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
08-05-2009, 03:08 PM
1966 24' Tradewind
Oak View
Oh you silly boy, where do you think I hide when the nuts come around??
08-05-2009, 03:14 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Quick! Somebody call Geraldo! Tell him Capone's treasure is in there!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
08-05-2009, 03:35 PM
1993 34' Excella
Estancia
, New Mexico
I'm not sure that silicone does anything more bad to aluminum that other materials, but maybe it does. If so somebody jump in. The bad stuff that silicone does it looks yuchy as it matures and it is a bear to get that stuff off aluminum.
You could remove the door and frame get a piece of aluminum and rivet it over the hole with bucked or Olympic rivets. Unless an AS afficianado no one would ever know. Zeppelenium recently did it with a couple of windows and did a thread about it. Then of course you could give the door to the needy through the forums. I'm sure someone needs it.
08-05-2009, 06:06 PM
1966 24' Tradewind
Oak View
Door to Nowhere
Hey, is it the size of the back door of a 1966 Tradewind? Mine flew off somewhere on the highway after I left C&G Trailer Repair on my way to Montana. When I called them about it, like, "You guys forgot to lock on my door and now it's gone," they said, "Oh, those things could come loose and fall off anytime." Well it didn't fall off since 1966......until now.
I ended up having a muffler place along the way fashion me one out of metal with a little lock, but it is rather flimsy and well, not pretty.
Anyone have one they want to donate? I am at an all time low on the cash flow as an artist.... or barter for art???
Carol
PS I know, I know, I should have checked everything myself before I left there..........
08-05-2009, 06:20 PM
Retired.
, At Large
Both Sikaflex and Vulkem are polyurethane sealants. Silicone adhesive, both RTV and caulk contain curing acids that are corrosive to the aluminum on Airstreams and similar coaches. I have seen aluminum etched by silicone, it does leave a mark. While I've never seen it actually eat a hole in a sheet of aluminum, I have seen it leave a stain on the aluminum that could only be removed by stripping, sanding, and polishing the area.
And the access doors on a 1970's model are different from the access doors on a mid-1960's model.
08-05-2009, 08:02 PM
Port Hadlock
I tend to get Vulkem from Vintage Trailer Supply - Vintage travel trailer parts and supplies! but many Fastenal stores have it as well (TremPro 636 "Vulkem" Polyurethane). We've got a local Fastenal just west of Peace Portal on Grandview, but I haven't tried them yet. I'm sure they can get it for you if they don't have it in stock.
08-05-2009, 10:49 PM
1978 25' Tradewind
Blaine
Cracking me up!
Thanks for the tips and the laughs.
By the Bay
08-06-2009, 07:16 AM
Retired.
, At Large
Cracking me up!
By the Bay
Remember, if you see a large white rabbit go through the hatch, don't follow him...
08-06-2009, 07:39 AM
2004 22' Interstate
Tipton
, Iowa
The former owner of the trailer wasn't a woman by the name of Sarah Winchester, was it?
Roger
08-06-2009, 10:15 PM
1978 25' Tradewind
Blaine
Y'all have helped me see the glamour and intrigue angle of our Door to Nowhere.
LOL
Silly me thinking it was just a run of the mill Leak Potential.
08-07-2009, 06:31 AM
1976 Argosy 24
Joplin
, Missouri
Most RV (SOB) supply stores and some mobile home dealers also carry Sikaflex. I buy it locally from a dealer in town, and I have seen it other places too. I find that a lot of things are stock with RV's, used in SOB's and Airstreams alike, and you can get replacements easily.
