Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 11-23-2003, 02:34 PM   #1
Where and how to climb on top of an AS
New airstreamer. How do you get on that roof without messing the trailer finish or killing yourself.
freud is offline   Reply With Quote
Old 11-23-2003, 02:54 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
VERY CAREFULLY>>>
It is safe to put weight on the crossmembers, the cross members are easy to locate attached rivets are the giveaway
Just stay over the rivets at the cross member seams or you will get some nasty dents.
Garry
Old 11-23-2003, 03:38 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I seem to recall threads mentioning carpet samples applied to boards to bridge between two or more crossmembers. Applied how? You wouldn't want any nail or staple to be near the carpet surface. Construction adhesive sounds better. How elaborate depends on your intentions.
Make sure any padding you use is new, has no grit, etc. You wouldn't want to scratch your nice clearcoat! Set it in place; don't slide.
Means of making it secure enough for safety are entirely up to you. Eight feet up is enough to cause some serious damage.
Mustn't be snowing in Montreal like it is here. Watch out -- it's coming your way.
5 meter Langford Nahanni
Old 11-23-2003, 03:47 PM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Exclamation Just so you know
freud
The other guys gave you good advice..One additional thing to remember: Whatever you do, Do Not try to access the top area from the end caps~! Either the front or rear..It much safer to tackle the roof top by the area in the middle..
Good luck~
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
