Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 10-03-2002, 05:12 PM   #21
overlander
Guest
Posts: n/a
the battery weighs ALOT. al least 75 pounds i dont know for sure ....they ARE heavy.
hey thanks for the info i'll try that
Old 10-03-2002, 06:34 PM   #22
overlander
Guest
Posts: n/a
what do you mean by it wont live as long? so will a small deep cycle last longer than an 8d with the same amount of draw? like say 20 amps?....i realize the 8d is for starting and has high CAA . but it also has a reserve. cat batteries in chronological terms last like three times longer than other batteries......but thats not being deep cycled, thats using them like they are supost to be used (starting...and ignition...lighting).
what kind of deep cycle should i use...... i'm looking for a battery that will last a long time without going dead. one that will store alot of energy and not fall on it's face like regular automotive batteries. i was thinking well i've got one auto battery when i hook two togeather i get more life out of a charge so why not just but one big battary in. i am not very familiar with deep cycle battaries but it would seem like they would work better if what i have heard is true..
question...will a small deep cycle out perform a very large industrial battery
Old 10-03-2002, 07:15 PM   #23
LOST , Hawaii
An 8D starting battery will put out a lot more current than something like a group 27 deep cycle. Where the deep cycle will outperform it is in the amount of times it can be discharged without harming it.
This is a good site for questions on batteries. They have alot of info on everything solar, which can be applied to what we do in RV's as dry camping is not a lot different than off grid power storage.
John
74Argosy24MH is offline   Reply With Quote
Old 10-03-2002, 07:21 PM   #24
overlander
Guest
Posts: n/a
Thumbs up
cool......thanks for the info.
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
'76 Sovereign vs. '76 Overlander tin can luv 1974 - 1979 Sovereign 14 09-13-2004 06:01 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Quick 12v Question Dave-O Electrical - Systems, Generators, Batteries & Solar 8 03-05-2003 03:37 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
