I got both inner and outer from ODMRV.com. HOWEVER.... they did not warn me that the "inner" wheel well cover does not fit over the wheel well. i.e meaning the one inside the coach, and supposed to go over the actual "exterior" wheel well does not fit. The original wheel well is black, and the inside cover was tan. Both are black for replacement option.
This appears to be the way it is... no other options available that I could find. I found another thread confirming same. You have to build up a frame on the inside of the coach around the perimter of the wheel well. Then the "inner" interior cover will attached to the built up base, and go over the wheel well. I might try to cut horizontally, and scab in a piece to make up the additional height needed so that I dont have to build up, and it will sit back on the floor. Its really only an insulation cover to further separate the outside from the inside... so I'm not super disappointed. It will be new.
