11-13-2005, 04:07 PM
1975 31' Sovereign
Oxford
, Mississippi
Working on top need help.
Help!!!! We were working on the trailor today resealing from the bottom up. I got the idea to climb up on the ladder to take a look at the top. Oh my gosh it has about 5 coats of everykind of caulk, silicon, and other funky looking stuff. What is the best way to get on the top so I can redo all the junk? Also
what is the best way to strip all that junk so we can redo?
Last night we had a terrible storm come through heavy heavy rain and the only leak we found was from the second vent the dome is cracked, where do we get replacement domes? And one more question the ac shroud is faded but in good shape has anyone painted one and if so how did it turn out?
Thanks for the advice,
Becky
11-13-2005, 04:53 PM
1986 25' Sovereign
Southern Middle
, Tennessee
Becky,
I borrowed scaffolding and then ran two 2X4's from the scaffolding to the top of the trailer. I put them on the ribs so that I did not dent the trailer top. I then layed a sheet of plywood on top of the 2X4's so that I could do caulk work around the vents. If I had one more side I could have put another set of scaffolding on the other side of the trailer and run 2X6's across so that I did not touch the top of the trailer.
I removed the Armstrong AC shroud using the same method as above. It had one inch cracks at two of the corners so I used JB Weld on both sides, sanded after it dried and then sprayed with Krylon white enamel. It turned out great.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
11-15-2005, 09:46 PM
1967 22' Safari
Branford
, Connecticut
Just up there this past weekend...
Hi Becky,
I spent some time on the top of my Safari this past weekend and didn't use any scaffolding to seal up my vents with vulkeum. I placed a ladder up to the side, padding the area that the top came in contact with my coach staying on the ribbed areas (you can tell where these are by the rivet lines). I was able to carefully crawl onto the roof by also sticking to the ribbed areas. You can sample an area before you put any weight on it with your hand first - it's easy to see whether it's a firm place or not. I had no problems at all and got everything sealed up (keeping leaves and acorns from sticking was another issue entirely!) I only weigh 125, but I seem to remember other posts saying you can do it without scaffolding. Check the archives out...maybe search for vent or roof repair and see what pops up. Good luck, Diane
11-17-2005, 07:52 PM
1973 31' Sovereign
Portland
, Oregon
I also did not use any scaffolding to access my roof. I installed 3 new Fantastic fans and removed/ reinstalled my air conditioner cover. I have a folding metal ladder that I leaned up against the side to get up. I used some of the foam wrap-around pipe insulation to cushion where the ladder leaned against the side of the trailer. I definitely believe what Andy says about walking on the trailer as far as the load bearing issue but I found that I needed to spend time on my knees to reach things. I bought some knee pads that were soft and flexible at Home Depot for something like $16.00. They were perfect for the job and they grip the surface nicely too. By the way at the time I was doing the work I weighed in at around 235lbs (I have lost some weight since then) and found that as long as I was carefull where I put my knees that all was fine. Keep in mind that things will roll off the top if you don't set them down near the middle of the trailer.
My AC cover was dingy and had some cracks in it too. Check out the following thread for some discussion of AC shroud repairs:
http://www.airforums.com/forum...eas-13372.html
Malcolm
11-17-2005, 08:27 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Unfortunately I have had to access my roof quite a bit...I usually use an eight foot step ladder and lean it against a rolled up awning. Wear boat shoes (non skid soles) and stay on the ribs as much as possible.And absolutely stay off the endcaps. If I need to spend any amount of time up there I will get a piece of carpet pad or thin foam cushion to sit or kneel on. It helps to have an assistant to fetch things you need while you are up there, like the scraper that just slid off and the occasional cold beer...funny never had one of THOSE roll off
Aaron
WBCCI #XXXX AIR #2495
11-17-2005, 09:11 PM
1975 31' Sovereign
Oxford
, Mississippi
Good advice
Thanks folks for all the info we are starting the roof this weekend. We had 2 major rain storms blow in this last weekend and we got most of the rain in our hallway below the a/c so we have to get it done now. Anyway the leak did little harm except wet carpet and we now have that taken care of. SO this weekend you will find us up on the top.
The Lacy's
11-17-2005, 09:33 PM
I was just up there today, nice view. I agree with moogie and andy(inland), I placed a ladder on the side of the trailer and climbed up. Andy suggest place the ladder on the drip cap? I did this and bent the cap. OOpps! Its best to stay on the "ribs" its a firmer area and less chance of denting the roof. Good luck.
Steve
11-17-2005, 10:23 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
inland has them in smoke and milk white.
they are expensive but worth it in my opinion. they are made of heavy gauge material.
i got the white ones and find they allow plenty of light into the trailer.
john
you call them ferrets, i call them weasels.
11-18-2005, 07:04 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Dwight
If you are not a purist, flat ones can be fabricated from corrigated polycarbonate with a aluminum lip around the edge to prevent rain entry. I like mine. Give plenty of light and are bullet proof. Have good insulating quality also.
11-25-2005, 05:28 PM
1977 27' Overlander
Huntsville
, Alabama
Up on the Roof Top
I am up on the roof this weekend and appreciate the info. Although I hear that Alabama is in the south it has dropped below freezing here. I didn't see any reindeer but it is certainly cold enough for them. I expect that it may get up to 50 tomorrow. I got fantastic fan vents and would like to install them this weekend. I looked at the tube of Vulcum that I have and there is no temperature restrictions printed on the tube. Does anyone know, is there a certain temperature below which the chemical won't cure. Can this be done in the cold or should I wait for a La Nina or global warming?
11-25-2005, 05:34 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Dusty,
I checked my Data sheets for Tremco Vulkem, there is no listed minimum tempature, but from expeirence I would not attemt to apply it below 40 degrees. Also the colder it is the longer it will take to cure, at 75 degrees it cures tack free in 24 hours and continues to cure at the rate of 1/16" per day "The cure rate is reduced at lower tempatures and humidity"...never knew it was THAT slow
Aaron
11-25-2005, 06:17 PM
1974 25' Tradewind
Yelm
Soooo, the burning question remains. How to remove a sea of goop of every describable kind. I have heard acrylic razor blades (to prevent scarring the aluminum). I used a regular razor blade but applied 2 doses of skill and patience and managed to get a small baseball sized area of some kind of sealer off successfully.
What to do when there is a large area ? In another case, I had more to remove and the stuff that I was taking off (kinda rubbery and black but not silicone) came off with Methylene Chloride, it bubbles it off. It is found in chemical paint strippers. A common one is Jasco, but a word of warning - it does not feel good when you accidental get even microscopic specks of it on your skin. It feels like you are being stung by a horsefly.
Also, it is carcinogenic and should only be applied in the presence of an organic vapors, fitted respirator. Aside from this I have limited experience and was hoping someone had better or more appropriate methods for taking of dried on goop and caulks. I have a bad job of silicone to take off around some of my vents this spring or summer and was hoping for some help.
On behalf of the Lacy's.
"It takes a village to raise a silver twinkie."
-Jim Phillips
11-25-2005, 06:41 PM
1977 27' Overlander
Huntsville
, Alabama
Lung Cancer
Oh, no. I have been liberally applying JASCO with only a mask. Guess I will change to the respirator tomorrow and get a chest xray the following day. Thanks for the word of caution Jim. Is JASCO the way to go with the overdone goop that Vintage AS seem to acquire with age from their POs. Aaron thanks for the info on Vulkem. We are headed for a high of 60 which of course will be followed by rain tomorrow. Any problem using it several hours before the rain?
11-25-2005, 07:26 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
If you can protect it for 24+ hours it would be better, FWIW when I redid my Vista Views I taped a piece of plastic over them until a rainy spell passed. I use the aluminum tape with the release paper....Lowe's sells it...IIRC it is in the heat duct area.
Aaron
11-25-2005, 07:32 PM
1977 27' Overlander
Huntsville
, Alabama
Great - will do for the warm front and rain that is coming. Glad it won't stop me from replacing the vents tomorrow. THX
11-25-2005, 07:35 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
JimmyJames,
A lot of it will depend on what the caulking is, there are a few commercial silicone removers on the market and they aren't cheap. One that I have used with some sucess is a citrus based solvent, the other is a automotive gasket remover, both of these are detrimental to the clear coat...if you still have any left. BTW the gasket remover spray was some super duper stuff from JEG's. I will try and find the name of the other stuff but it was about $50 a gallon I also use MEK (methy ethyl ketone) I would reccomend at the very least using a pair of chemically resistant gloves with it.
Aaron
11-25-2005, 07:40 PM
1974 25' Tradewind
Yelm
Oops, Dusty makes a good point. Perhaps I was being alarmist. I caution others on the risk of using or buying Methylene Chloride when I should not have. My apologies.
Since information has "survival value", here is some more information on the stuff. Don't concern yourself unnecessarily, it sounds like you have to be sick already or expose yourself for a while before this could pose a "real" risk. It just seemed like a nasty chemical to me when I used it but I'm a chemical pansy. I can't even be around people who smoke....consider the source.
EPA Hazard Summary-April 1992; Revised in January 2000
Methylene chloride is predominantly used as a solvent. The acute (short-term) effects of methylene chloride inhalation in humans consist mainly of nervous system effects including decreased visual, auditory, and motor functions, but these effects are reversible once exposure ceases. The effects of chronic (long-term) exposure to methylene chloride suggest that the central nervous system (CNS) is a potential target in humans and animals. Human data are inconclusive regarding methylene chloride and cancer. Animal studies have shown increases in liver and lung cancer and benign mammary gland tumors following the inhalation of methylene chloride. EPA has classified methylene chloride as a Group B2, probable human carcinogen.
-Jim Phillips
11-26-2005, 07:33 AM
1977 27' Overlander
Huntsville
, Alabama
After reading your posts last night, I got nervous so I read the JASCO can. The exact wording was "This product contains a chemical known to cause cancer in California" Slept well knowing that I am safe here in Alabama where I can only assume that it does not cause cancer. I can't stand smoke either but was not particularly chemical shy until I met my first can of JASCO. Anyone considering using the stuff should be in full painters suit with neck protection, full face protection including goggles to even think about using it. I would also recommend a clean container of fresh water with a cloth for flushing your skin within 5 feet of the area for accidental exposure. I have been stung by wasps that did not hurt as bad as microscopic drops of the stuff. I am headed to the hobby shop to spend a gleeful day on top of the silver baby replacing, scraping and sealing.
11-27-2005, 07:21 PM
1973 31' Sovereign
Portland
, Oregon
Check out the following company website for a product that I discovered that really does help with removing silicone caulk. The product is called Amtex-CCR.
http://www.amtexchemical.com/pages/13/index.htm
It does help to remove what you can easily get off with a razor blade or scraper of some kind and then let the chemical do the rest.
Malcolm
11-30-2005, 06:14 PM
1974 25' Tradewind
Yelm
Be careful
Thank you malconium !
Don't underestimate chemicals when working on your coach. Read the warnings and do what they say... signed:
A chemical pansey.
-Jim Phillips
