Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 07-27-2018, 04:48 PM   #1
Sdmezurek's Avatar
1970 27' Overlander
West Salem , Ohio
To belly pan or not.....
Belly pan or no bellypan... And was something else used as an alternative?? Reasons why please and thank you!
Sdmezurek is offline   Reply With Quote
Old 07-27-2018, 07:55 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most of the SOB'S are using something that looks like corrugated plastic.
Don't know why it would not work on an A$.
Especially if you keep the banana wrap.
Old 08-17-2018, 05:46 AM   #3
Maj Nelson's Avatar
1984 31' International
Batesville , Virginia
I've been thinking about using frp board. It only comes in 8' sheets at the big box store, but I plan on replacing the belly in multiple pieces anyway. Painted black, I think it'd look like undercoating.
What I really wanted was rivets, by heaven! Rivets. To get on with the work... to stop the hole.
Maj Nelson is offline   Reply With Quote
Old 08-18-2018, 10:02 AM   #4
1963 28' Ambassador
Northern VT , Vermont
Yea belly pans are a pain.The parimiter goes up under the body panels at floor level just above the C-channel. Pretty much no way to replace it completly with out removing the body. Covers all the sharp edges including outriggers and most importantly keeps water ect away from the floor edges. If, big if your belly pan is good down around the parimiter curve replacing the flat bottom is'nt to bad, all flats. Just cut out the old and rivit in the new. I just bought 3003 T14 4x8 sheets .032 thick for $44.00@.
putback is offline   Reply With Quote
Old 08-18-2018, 11:57 AM   #5
Maj Nelson's Avatar
My '84 31' International, the belly tin was exterior of the wall panels, covered by the C channel. Either a factory trainee made my unit or one of the POs didn't understand how water/gravity works. All the rivets looked factory though, not DIY.
Anyone else find their wall panels inboard like this?
Old 08-18-2018, 03:59 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My Argosy is the same way. The banana wrap is outside of the exterior skin with the rub rail clamping over both.
It's no wonder water gets in and ruins the floor. The area where the trunk lid attaches is like a funnel that collects water which seeps in under the C channel and in to the plywood.
It is really a lousy set up.
Old 08-19-2018, 07:49 PM   #7
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Mine came that way too. I replace the wraps and buck riveted under the shell. I think this maybe a 70's thing. It's a horrible building practice hopefully still not being done.
Matt
rugjenkins is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
belly pan ....needed....or not????? leefields Repairing/Replacing Floor &/or Frame 10 01-09-2006 12:15 PM
Belly Pan Gaps? ajjohnsons 2000 - 2004 Safari 6 07-22-2003 07:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
