Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 05-16-2011, 08:21 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Dry fitting shell..shims needed?
We'll be dry fitting the shell to the new floor/chassis on our 1964 Bambi II. Since the banana wrap won't be in place when we dry fit it, do we need to put some kind of shims between the channel & the skin of the shell to act as the space the banana wrap would take up? We're not permanently attaching the channel to the floor so we can adjust it when dry fitting. Thanks for any advise!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-16-2011, 10:06 PM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Becky,
Since we started doing Rotiserrie chassis restorations, we always fasten the "C" channel to the floor & complete the bellypan, before attempting installation of the body. Inserting the bellypan corners will be a nightmare if you try to slide them between the skin & the "C" channel after the fact.
Colin
Colin H is offline   Reply With Quote
Old 05-17-2011, 05:44 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
We were going to try a dry run before I make the banana wrap to see if we're close enough with the c channel and shape of the floor. I'm pretty sure I saw this done on other shell-off's before they're committed to the permanent installation of the c-channel. We're going to lift the shell off again after the dry fit and then I'll make the banana wrap. It will be installed before putting the shell on again. My main question is whether to put some kind of shim in to make up for the banana wrap that won't be there yet.
Becky
1964 Bambi II
1988 Avion 32S
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell off or on? Breadbug Repairing/Replacing Floor &/or Frame 3 02-06-2011 11:06 AM
custom build help needed tjr General Repair Forum 4 01-30-2011 12:05 PM
