Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 07-07-2009, 06:42 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Bellypan Replacement Project
Well, I cleaned and sealed the exposed frame members, installed the foam board insulation, and riveted the new aluminum in place. Thanks for the advice from forum mambers. I've only done the rear, behind the tanks section, but I feel, with time and work, I can do the rest of the trailer. Here is a picture of the foam board, and a handy bellypan holder while I riveted it in place.
Name:	Foam Insulation.jpg
ID:	83551   Click image for larger version
Name:	Bellypan Holder View 3.jpg
Old 07-07-2009, 07:13 AM   #2
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
Nice work. I especially like the pan holder using the custom sized chunk of concrete!!!! That looks like some pretty hefty pan material.
Greg
Roadtoaster is offline   Reply With Quote
Old 07-07-2009, 09:33 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Cool! how did you secure the foam? (is that 5" of the rigid pink foam board stuff?)
when you do a new belly pan, do you use the old rivet holes, or just hold the alluminum in place, and drill all new ones?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-08-2009, 05:59 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I used 2" foam board insulation. I cut it to fit in the frame cross member openings, which are about 57" wide and 24" long. I used a foam board construction adhesive and the caulk gun. The foam fit snugly in the openings. And I used two pieces for a total of 4". We're from Minnesota where it's always cold! The foam board did not absorb water after two days submurged in a pan of water. I think this is better than the wet fiberglass batting that was in there origionally.
The aluminum is .025 on 48" coil. I cut it to 60" long panels, and created a 60" wide by 7 foot long sheet with riveted seams every 48". I marked the center line of the sheet at 30". And I marked the center line of the frame. It is important it lines up on center before the riveting begins. Then I held it in place with the 2x4 holder and cement block risers. I drilled and riveted all afternoon! I did not attempt to use the origional holes.
I am trying to decide if I should drill some drain holes in the bellypan. The bumper wraps, sewer hose storage area and lid are not sealed, and allow rain water to run into the belly pan area. Why not let it drain out? The photos show the old bellypan corrosion, and the rear bumper area that is open to the elements.
The front of the trailer, ahead of the axles, is much longer at 24 feet. But I will use the same method. It will take me a good week of work to get it done. Maybe next year as we have traveling to do this summer.
David
ID:	83650   Click image for larger version
Name:	Clamps holding bellypan at rear.jpg
Old 07-08-2009, 06:54 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
interesting. I'd be concerned that any water that does manage to get between the foam and the plywood would just sit there, and rot out the floor from underneath.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-13-2009, 04:42 PM   #6
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Hmm, I am thinking the same as Chuck. I'm in the midst of this and will probably put spacers o a 1/2 to 3/4" and attach the foam. This will give some airspace for drying should it get damp.
SilverHoot is offline   Reply With Quote
Old 02-25-2010, 04:22 PM   #7
1970 23' Safari
Ventura , California
I too am going to be replacing my belly pan and was reading about letting the water drip out. But am worried about spiders and insects getting up in there. So I was thinking maybe gluing a metal mesh on the inside on the aluminum sheet over the holes?
PS> What's the difference between belly pan and banana wrap?
jaminalee is offline   Reply With Quote
Old 02-25-2010, 06:05 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
The banana wrap is the piece that wrap around the perimeter of the AS and is riveted into the lower side of the skin and the belly pan.
bwaysteve is offline   Reply With Quote
Old 11-10-2010, 12:06 PM   #9
Fenderonly
2006 19' Safari
Nashville , Georgia
belly pan
Newbie here from Georgia. Been reading this post on the belly replacement, a great help as I need to do the same!
Just got a 1987 Excella 1000, 32 feet a few weeks ago. Very nice, just a lot of TLC needed! Excellent original wood cabinetry, new hardwood floors, super nice original upholsetery and Airstream beds. Wood curtains still in front and dinette area.
So far:
All new clearance lights
New tires and shocks (American made Marathons!)
5 sets of mini blinds and replace screens on same windows.
Recertified and new heads on aluminum propane tanks
New regulator and hoses for the tanks
Rebuilt Moen kitchen faucet (cartridge, o-rings and aerator)
New gasket for hood fan vent (leaking water there)
new A/C filters
Lots of cleaning and polsihing!
Been on our first trip to Oklahoma and now back in Alabama a few days. Towing with a Hensely hitch and Dodge RAM.
Amazing, I am getting close to 15 MPG, 3-3.5 MPG better than my Fleetwood 24' that was 2000 lbs lighter.
More projects to do ASAP:
-Clean drapes and replace all the glides on the ones by the Dinette area
-replace belly pan behind and in front of holding tanks
-replace the Univolt with a more modern, regulated supply.
Great to be here and appreciate the Forum very much!!!
fenderonly is offline   Reply With Quote
Old 11-10-2010, 12:48 PM   #10
Lothlorian's Avatar
Loganville , Georgia
DJ:
I like what you used to put the aluminum up with. The concrete block and wood. I have to change mine out because at the time I could not afford the aluminum. Now I am motivated to put a new one up.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-23-2011, 05:56 PM   #11
n8andm's Avatar
Minneapolis , Minnesota
Thanks for posting
I have been looking for posters in the Minnesota region to know what they have been doing for our special climate conditions. I have to replace the belly pan on our Silver Streak. Where did you get your aluminum and how much was it?
n8andm is offline   Reply With Quote
Old 02-26-2015, 06:59 AM   #12
MyNancy1977's Avatar
What's the best tool to cut sheet metal...thus is what I have to deal with
ID:	233148   Click image for larger version
MyNancy1977 is offline   Reply With Quote
Old 02-26-2015, 07:05 AM   #13
aquinob's Avatar
Portsmouth , Virginia
You want to try and drill out as many of the rivets as possible, then it should mainly fall down. If you can get the pan out intact, you may be able to reinstall it or use it as a pattern for a new piece. Just about any type of saber or jigsaw with a metal blade will cut through it. You could probably rip it out since it looks like its mostly gone with corrosion anyway.
Ongoing adventures at:
https://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 02-26-2015, 07:39 AM   #14
mover75
1991 34' Limited
waller , Texas
spray foam
Has anyone used or had the bottom side of the floor panels sprayed with closed cell foam insulation that is used in homes while having the belly pan removed? If so what type of results did you have? Thanks
mover75 is offline   Reply With Quote
Old 02-26-2015, 07:52 AM   #15
1955 22' Safari
Laredo , Texas
Angle grinder or dremel tool with metal blade will cut the pan pretty easily. I cut mine out only between frame rails when installing tanks, leaving banana wraps in place.
55AS is offline   Reply With Quote
Old 02-26-2015, 08:00 AM   #16
1976 31' Sovereign
Oswego , Illinois
If I replaced belly pan I would pull all of insulation under floor out as fiber glass soaks up water then where ever wet floor rots out also causing frame rust. Trailers that are not used in frigid weather does not need insulation, the only reason I see is sound deadener. Many other trailers do not use belly pans or put insulation where would get wet, weep holes in belly pan good idea, insulation bad.
Old 02-26-2015, 08:04 AM   #17
Thanks so this is the whole belly pan right , it has patches as you can see.this was way south of texas san benito...sat for 9 years
Old 02-26-2015, 08:05 AM   #18
Here's water tank...what do I do there , it don't work anyway
Old 02-26-2015, 09:02 AM   #19
aquinob's Avatar
The water tank is held up in place by a piece of 1" thick plywood that sits in rails. The downward face of the plywood is covered with a sheet of aluminum just like the bellypan. I dropped the tank and documented it some here:
My Airstream Adventure, Making a 1973 Overlander Our Own.: Dropped the FW tank and here:
My Airstream Adventure, Making a 1973 Overlander Our Own.: Tank is back in, new outrigger covers fabricated and weled. Wheels are finally all on.
Old 02-26-2015, 09:10 AM   #20
aquinob's Avatar
It would probably work well for insulation but I wouldn't do it. One of the biggest issues with the original spun fiberglass insulation is that it tends to hold water up against the frame and promote rust over time. If you spray the whole bottom of the frame with this stuff, you will cover up some of the frame and thereby encapsulate it. If water can get in (and it will find a way) then you have set yourself up for trouble.
The best solution I have found is to use the solid foam boards cut to fit underneath between the frame members and held up with screws and fender washers. This should let the frame dry if any water can get up underneath since it can drip down and out. Remember, water that gets between the the interior and exterior skins wont be seen unless its a lot and you can notice staining on the plywood floor. It will eventually run down to the bottom as well and you don't want it to hang around any longer than necessary.
Here is a link to show how it came out on my rig: My Airstream Adventure, Making a 1973 Overlander Our Own.: Progress but at the cost of an eye injury
Bellypan re-attaching Annabel Belly Pans & Banana Wraps 30 06-21-2009 01:48 PM
Bellypan installation Safari Tim Belly Pans & Banana Wraps 21 08-23-2007 06:58 PM
Bellypan Woes Uncle Jack Belly Pans & Banana Wraps 2 07-02-2007 03:10 PM
Scrap the bellypan? dmaiden Belly Pans & Banana Wraps 10 11-04-2006 03:29 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 09:41 PM
