Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 10-22-2007, 02:24 PM   #1
Profile:  1972 27' Overlander
cass , Texas
Steps will not stay put
When I step upon the fold out step's they will not stay put in their nothes. They will give to either side. If I replace the bolts that go into the main body will that solve my problem? Thanks
krazeekalvin is offline   Reply With Quote
Old 10-22-2007, 02:36 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Steps
I saw this solution at the Branson rally.
The top has a T sweated on and the bottom has one with a slot to fit over the back of the step.
http://www.airforums.com/forums/atta...4&d=1192908130
I haven’t made my own yet, but plan to. My steps are behaving like yours.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
Old 10-27-2007, 10:09 AM   #3
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
So??
As I see it..
The idea is to just place the T in place by friction?? KEWL..
Thanks for sharing the photo again...
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 10-27-2007, 10:16 AM   #4
1967 24' Tradewind
Images: 32
Rivet Step Supports
Originally Posted by 53flyingcloud
As I see it..
53FC
Hi 53FC,
That’s right. He told me to make them slightly long so you have to lift the step to slip the top in and ease them down solidly. They worked very well. I also saw a commercially made similar single T adjustable product, but the homemade ones appeared superior. By making them the exact length needed, they can never be out of adjustment. The cost is just 4 Ts and a few feet of tube.
Vaughan
Old 10-22-2007, 03:11 PM   #5
Commercial Vendor
Profile:  Corona , California
The notches are worn out in the two footstep outriggers.
You can weld steel in the grooves and then grind it out to fit, or, you can replace the outriggers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-22-2007, 03:33 PM   #6
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
This is what I'll be doing to mine... when I get there.
It's alway good when Inland Andy confirms my plans... thanks Andy!
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-27-2007, 07:10 PM   #7
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
You can get the step outriggers at any Airstream dealer. I just replaced mine this summer. They are $16.00 to $18.00 depending on what dealer you get them from.
Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
Yamaha 3000
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-27-2007, 08:56 AM   #8
cass , Texas
Thanks for all your help.
Old 10-27-2007, 10:24 AM   #9
Savannah , Missouri
Aha..
Thanks for the additional tip, I can see how that would be..
My steps are not bothering me just yet.
It's always good to have the know how..
And, another little project to add...
ciao
53FC
Old 10-27-2007, 04:29 PM   #10
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
I have the same problem. Are the replacement brackets readily available at a reasonable cost - i.e. - cheap enough to make jury-rigging not worthwhile?
Cracker
Cracker is offline   Reply With Quote
Old 10-27-2007, 05:01 PM   #11
1967 24' Tradewind
Images: 32
Rivet Replacement Brackets
Good question. I created a detailed reply concerning home made braces vs. aftermarket ones. Only when I was about to post the reply did I realize that you were talking about solving the problem in the first place.
I looked online for the replacement brackets but came up dry so far. Does anyone know of a source for these?
Vaughan
Old 10-27-2007, 05:57 PM   #12
Elkhart Tool makes a unit for total replacement. Check out unit #424
Steve & the crew
Old 10-27-2007, 09:22 PM   #13
bilby05's Avatar
Profile:  1969 31' Sovereign
Canyon , Texas
Double Steps
I noticed in the photo of the brass tubing tool that it is attached to a two step set. Our AS has the single step type and we would love to get double steps. Wife just had a total knee replacement a couple of months ago and my knees are wearing down fast. Does Airstream make a dual set that will fit a '69 Sovereign? or do you have to purchase an aftermarket one like the elkhart tool ones?
thanks, bill b.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 10-28-2007, 06:11 AM   #14
Commercial Vendor
thanks, bill b.
Airstreams double aluminum footstep will fit your 69, but you must change the footstep outriggers and add a release bracket at the bottom of the entrance door.
Andy Rogozinski
Inland RV Center
Corona, CA
I put something in my oil? ArtStream Tow Vehicles 4 10-24-2007 12:22 PM
Where should one put a stereo? gergstuff All Argosy Trailers 11 06-14-2007 07:09 PM
Put me in a harness... bevman Batteries, Univolts, Converters & Inverters 10 04-02-2007 02:03 PM
Wasnt for sure of where to put this.... Angel73 General Interior Topics 15 05-05-2006 08:31 PM
And Now to put it back together. 59toaster Cabinets, Counter Tops & Furnishings 50 10-23-2005 07:56 AM
