Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-09-2011, 10:18 AM   #1
flyingcloud's Avatar
2012 27' Flying Cloud
somewhere , on the road
Images: 8
Xzilon Coating from Sutton RV
Hi all -
We just ordered a 2012 Flying Cloud from George Sutton RV. They are recommending that we get a Xylon exterior sealant that they apply to the trailer at the dealership. Apparently they're the only dealer that does it and it prevents corrosion.
Does anyone have this on their trailer? Are you happy with it? More information would be appreciated.
Thank you!
Our blog: Aluminarium
Find & Share Great Campsites: Campendium
flyingcloud is offline   Reply With Quote
Old 05-09-2011, 10:28 AM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Correct spelling seems to be Xzilon.
Looks like it's expensive - how much are they asking to do the Airstream?
Al - K4GLU is offline   Reply With Quote
Old 05-09-2011, 10:34 AM   #3
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Hmm, if you Google either spelling, you'll sure get some varied opinions. Wonder what Andy's experience is? That being said, Sutton DOES have a good reputation.
Mike Leary is offline   Reply With Quote
Old 05-09-2011, 10:35 AM   #4
Images: 8
$1400 for 27 feet...
Old 05-09-2011, 10:42 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Pretty useless website: Xzilon® Molecular Adhesion
Example from FAQs:
"What is the Xzilon® Limited Warranty term?
If you have already purchased Xzilon®, review the Xzilon® Limited Warranty that you received from the selling dealership. Otherwise, ask your authorized Xzilon® selling dealer for more information."
The rest of the website is just as informative.
Vaughan
Old 05-09-2011, 11:00 AM   #6
Mike Leary's Avatar
Ajo , Arizona
Cripes, how would you warranty something like that? If someone is hyping it as a way to prevent scratches, I call bull.
Old 05-09-2011, 01:29 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
The aluminum surface is clearcoated prior to assembly. Usually the clearcoat fails due to filiform corrosion between the aluminum and the clearcoat rather than due to degradation of the upper surface of the clearcoat. Adding more clearcoat will not prevent it.
Old 05-09-2011, 02:45 PM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have a good feeling that when you read the fine print you will find out that if the product fails that the dealer will reapply the product again at no charge to you.They will not repair any damage caused buy corrosion.Most customers fail to read the warranties.
Old 05-09-2011, 03:20 PM   #9
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Id save my $$ for something else.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 05-09-2011, 03:23 PM   #10
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
If you coat the lacquer on the aluminum, the coat bonds to the lacquer but does not change the bond of the lacquer to the aluminum. Any coating is as strong as the weakest electron-bond.
This will do nothing for your airstream, long term.
TX-16
Dave Park is offline   Reply With Quote
Old 05-09-2011, 04:48 PM   #11
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Additional dealer profit comes to mind.
Michelle TAC MT-0
Sarah, Snowball
Old 05-09-2011, 06:23 PM   #12
Retired.
. , At Large
You're not even coating the aluminum, you're coating the plasticoat that coats the aluminum. The only benefit would be along the edges where the plasticoat has been compromised, like around lights, windows, and seams.
Old 05-09-2011, 07:53 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
I fully agree with every single negative opinion voiced on this product. Day in/ day out solar ultraviolet will eventually degrade the aluminum-plasticoat bond. I store inside and I still can't bet that I'll have better results at the 10, 12 or 15 year point.
For example, the ultraviolet protectors in spar varnishes are sacrificial; ie, they are destroyed as they do their job. Therefore spar varnishes have to be renewed every year. Is the warranty dependent on reapplication? You'll not want to be spending that kind of $$. Spend it on storage under cover in my opinion.
5 meter Langford Nahanni
Old 05-09-2011, 07:58 PM   #14
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I agree
UAPachyderm is offline   Reply With Quote
Old 05-09-2011, 08:24 PM   #15
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Read 2Air's opinion from 2006 here:
http://www.airforums.com/forums/f441...num-26573.html
JStanley is offline   Reply With Quote
Old 05-09-2011, 09:20 PM   #16
wendywoods's Avatar
2010 28' International
Somewhere , Mostly California
I emailed Leigh some links as well, which may be of some use. Cheers! Wendy
wendywoods is offline   Reply With Quote
Old 09-08-2011, 01:16 AM   #17
2001 23' Safari
Sanford , Florida
Xzilion
Originally Posted by UAPachyderm View Post
I agree
The real xzilion is made from a company called Granitize. They make it for auto and aerospace. There is formulas for paint and formulas for aluminum. It normally takes 3 coats depending on the type of formula you purchase. It's great for keeping oxidation and salt spray from the aluminum. Thus reducing the need to polish metal or paint frequently. Most applications will only last 1 year not the 5 years as claimed by some. Applying the product correctly is key or you will end up with smears that are really hard to remove. Beware of imitations on the market. They are sold frequently on eBay. I use this product on aircraft frequently and have found it to do it's job. It's not a miracle, just reduces overall long term work load and the fight against corrosion and oxidation. I have a stockpile of kits if anyone wants the real stuff. I get them at a contractor price. Contact me if you have any questions about Xzilion or would like to purchase some. I am a polished aluminum master. It's my job to make it shine.
Aerobling is offline   Reply With Quote
corrosion, sealant
Stove Top Powder Coating Ganglin Stoves, Ovens & Microwaves 15 03-31-2017 09:54 AM
Corrosion Kirbys Ribs, Skins & Rivets 4 01-19-2011 06:39 PM
