Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 07-28-2014, 08:37 PM   #1
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Stripping painted airstream.
A friend of mine is thinking about buying this 1961 airstream. Does anyone know how much work it would be to strip the paint? Do you think it would be worth it? Any input would be awesome!
Name:	ImageUploadedByAirstream Forums1406601411.985087.jpg
ID:	217705Click image for larger version
Name:	ImageUploadedByAirstream Forums1406601424.443886.jpg
ID:	217706Click image for larger version
Name:	ImageUploadedByAirstream Forums1406601436.907503.jpg
ID:	217707Click image for larger version
Name:	ImageUploadedByAirstream Forums1406601445.643338.jpg
Heliguy63 is offline   Reply With Quote
Old 07-28-2014, 09:00 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Here's the problem, it was likely painted because they used bondo to fill in dents. Paint and voila damage is gone. Take the paint away and you are going to have to do a shell off to repair damage.
The paint itself doesn't appear to be adhering well, so that's good. Should be easy to remove .
BUT, if they sanded the Airstream to make the paint stick ( as they should of ) well, then they will have to repaint.
It's not an Argosy right?
I'd steer clear unless they can verify no bondo and no sanding.
reinergirl is offline   Reply With Quote
Old 07-28-2014, 09:08 PM   #3
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
It's not an argosy. I think they painted it white because they wanted to keep the heat down In the trailer as it is located in a desert location. Assuming no dents, sanding and bomdo. Do you think stripping would be a huge task? How about a $1000 for the trailer? Do you think it would be worth it.
Old 07-28-2014, 09:18 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would buy it for a grand, even if it meant that I had to end up painting it.
The way the paint is peeling of I am betting it wasn't sanded. Or at least it wasn't sanded well.
Probably painted with house paint, if so it will strip easy.
Old 07-28-2014, 09:21 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
As a matter of fact, after looking at the pics again, I would be all over that for a K.
Old 07-28-2014, 09:26 PM   #6
reinergirl's Avatar
Me too!
Old 07-28-2014, 09:27 PM   #7
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
get some citrus strip from the box store both hd and lowes carry it and hope they painted on the clear coat if so buy a second bottle and remove the clear coat also!
cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-28-2014, 09:30 PM   #8
1966 17' Caravel
OBTW a thousand really?!? you all have too much money! Talking about the paint job then gonna throw a k at it?!? Good luck only offer what you are comfortable with they may jump on it!
Cliff
Old 07-28-2014, 10:38 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is worth a thousand in scrap value.
I could make quick work of that trailer with an air chisel....
Old 07-29-2014, 04:56 AM   #10
1966 17' Caravel
Not so much unless things have seriously changed in a month! To get any scrap value it must be stripped and separated and then an overlander maybe 350. Aluminum 150. Steal (if they don't know the axles are rubber filled) and the copper another 75. After you remove the brass! Insulation will kill your wire value! Yes I ask foss and they had a valuation sheet for cars and trailers!
Cliff
Yes I said that! Or did I?
Old 07-29-2014, 06:00 AM   #11
3202 Ellie
boliversr's Avatar
1975 Argosy 24
milan , Michigan
1 K seems like a good price if you are looking for a project please do not scrap
boliversr is offline   Reply With Quote
Old 07-29-2014, 01:05 PM   #12
1966 17' Caravel
Scrap is always a last option but it is recycling and the usable parts and pieces are sold to those who need! When an airstream gets to a certain damage from an accident or misuse run away corrosion or a tree falls on it then it is time for the scrap yard!
Cliff
Old 07-29-2014, 01:30 PM   #13
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Thanks for the input. We will see what happens! It would be a project for sure.
Old 07-29-2014, 05:52 PM   #14
68Streamline's Avatar
Cerritos , California
Its true what other people are saying about covering dents with bondo/paint. We recently stripped a 21 footer and found the dents they were hiding. After 7 gallons of Aircraft Stripper we were able to bring back our Airstream to its original bare aluminum. Oh did i mention there were 4 layers of paint?
68Streamline is offline   Reply With Quote
Old 07-29-2014, 06:35 PM   #15
JimGolden's Avatar
1977 31' Excella 500
I'll basically echo the other folks here.
Get some good airplane paint stripper, squirt it on, go drink a few, hose it off, repeat as needed.
Just might want to do it out in the desert where the EPA won't see you
Seriously though, looks like Mother Nature has got a head start on it for you. If there aren't a bunch of big dents, I'd sure go $1000 for it.
Best of luck!
- Jim
JimGolden is offline   Reply With Quote
Old 07-30-2014, 12:58 PM   #16
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Four layers! Jezz! That's a ton of paint! I don't think with the lack of quality on the paint job they would have taking the time to bondo. But you never know.
Old 08-10-2014, 09:40 AM   #17
RacerX's Avatar
1964 22' Safari
Walnut Creek , California
Images: 8
It's a screaming buy at $1K for a project trailer.
Mark, Norby, Nicci and (occasionally) Matt
"The reward for work well done is the opportunity to do more." Jonas Salk
RacerX is offline   Reply With Quote
Old 08-31-2014, 07:53 AM   #18
1968 22' Safari
Weatherford , Texas
Can I use a Hoime Depot stripper and knock it off with a power sprayer?
pysport is offline   Reply With Quote
Old 08-31-2014, 07:59 AM   #19
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yes, that method works well.
Buy Kleen Strip Aircraft Remover, NOT the " "low odor" version.
Stripping A Painted 31 Intl. Different types of AL? redthies Cleaning, Stripping & Polishing 1 06-20-2010 10:48 AM
advice needed on painted Airstream keith53 General Motorhome Topics 6 03-26-2008 04:59 PM
Nissan Altima painted "Airstream Silver" Road Ruler Off Topic Forum 4 07-19-2007 02:06 PM
Stripping painted A/S? mlium Cleaning, Stripping & Polishing 2 10-12-2004 02:31 PM
stripping the grey painted bottom ALANSD Airstream Motorhome Forums 6 07-11-2004 07:33 AM
