Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 11-10-2002, 11:23 PM   #15
LLB21
LLB21's Avatar
Profile:
Try C&G Trailer Service in Bellflower, CA (CGTrailer@aol.com). They have insert by the foot and prices have dropped recently. They have lots of new and old Airstream parts. They've been around for many years working on Airstreams only. Their place looks like an Airstream museum.
Louie
LLB21 is offline   Reply With Quote
Old 11-11-2002, 08:09 AM   #16
NewStreamer
NewStreamer's Avatar
Profile:
Louie,
Thanks for this most valuable info. Sure is good news to have a choice of supliers
Ron
NewStreamer is offline   Reply With Quote
Old 11-11-2002, 09:26 AM   #17
hex
hex's Avatar
Profile:
Arrow Excella Blue Trim Band
If I understand this right the Wide Excella Stripe is rolled aluminum flashing (w/ blue vinyl bonded during manufacture and plasti-coat applied ??). It is apparently held in place by the trim mouldings. would it really be a good candidate for a painting that'd last long due to the vinyl and plastic-coat? But then you could paint it every couple of years I guess.
I think a decal would be hard to apply (wrinkles & bubbles) and even harder to remove later. Also it would suffer from the elements over the years.
Perhaps the aluminum band could be removed and turned over? And the back primed and painted successfully? Way too much trouble for the return.
or
Factory painted aluminum flashing (colors baked on) used to be available thru sheet-metal shops, aluminum carport/sunroom etc dealers, and custom continuous-gutter dealers. Why wouldn't this product work?
Am I right to assume the trim is riveted on and that the rivets also pass thru the aluminum flashing? If so you'd sure want to use the old to pattern the holes in the replacement flashing. Can I assume the whole band is one continuous piece?? Unfortunately it looks like the removal/replacement job would 'open-up' many possibilities for leaks behind trim at rivet holes. (areas where it would be hard to apply sealer).
Just paint it!
hex is offline   Reply With Quote
Old 11-11-2002, 10:24 AM   #18
74Tradewind
74Tradewind's Avatar
Profile:
Look on ebay
I saw a roll of the thin Airstream vinyl on ebay.
www.ISellThousandOaks.com
74Tradewind is offline   Reply With Quote
Old 11-11-2002, 12:31 PM   #19
Cat
Cat's Avatar
Profile:  Mukilteo , Washington
Images: 8
Blue Stripe
I think if you ask the pros on this subject, you'll find out that painting the stripe area is the worst thing you can do...for several reasons.
First of all, as I understand it...
(and to those who think I don't pay attention...listen up),
...the original has been "Acrylic Coated" along with the rest of the exterior...and you would be painting over that; the bonding of the two is "iffy" at best. (read below)
Plus, in my humble opinion, painting anything that is not able to be sanded well and prime coated, and sanded again --- WHAT A "BOTHER"!!---is troublesome, at best.
The proper use is a stripe called Vinyl Clad, and if you ask for it by name at that place mentioned in this Thread..or ask Andy at InlandRV (on this Forum also), you can find it sold by the foot I think. I'm very close to ordering mine for "Bear"
Anyway, I am a professional designe, and deal with professional painters every day, and I say painting is to be done ONLY when you don't want to do it as a "remedy". And if you do want it for that...be sure you do it RIGHT...and plan for future "re-dos".
Somethings just should not be compromised...
HAVE YOU EVER SEEN A POOR PAINT JOB (the wrong paint) used on the "Under Belly" of an Airstream...it is GAWD-AWFUL !.
In my way of thinking, the stripe would turn out to look pretty bad too, UNLESS you FIRST OF ALL taped off, then sanded well, then prime painted with an OUTDOOR MARINE basepaint, then SANDED again, then a BASE coat of your BLUE colour in another OUTDOOR MARINE paint...SAND AGAIN, the the top coat of a VERY SHINEY OUTdoor marine coloured paint AGAIN. Then, a TOP TOP coat of an outdoor CLEAR finish---like Acrylic.
The problem with all of this...is how do you get it all off when you want to REDO it? A mess! You canNOT remove the old prior to repainting it. And this would be a definite situation in a few years with the UV rays getting to it.
I personally will just get the "Vinyl Clad" from a supplier...and pray the next time I need it it's still available.
(Sorry...a little more than 2 cents worth)...
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 11-12-2002, 03:02 PM   #20
hex
hex's Avatar
Profile:
Talking Don't U make My green Eyes Sea Blue?
OK Cat. I am wondering about your Airstream. In the Avitar picture it appears to me that the whole thing has a blue hue. Looks kinda like a transparent stain job.
Surely I'm halucinatin' eh Cat?
After all you don't call it the "blue bear"
Too much blue nun at breakfast ?
Old 11-13-2002, 03:46 AM   #21
Cat
Cat's Avatar
Images: 8
Blue Bear
haha...hex..
that's the reflection of those Blue Skies in Seattle. Haven't you heard about them? And Bear is so shiney...well
what can I say? Put your "shades" on?
Old 11-13-2002, 10:59 PM   #22
Cat
Cat's Avatar
Images: 8
Blue VInyl Clad
The small lower blue stripe is coming off Bear...EEEEEeeeeeeeeekkk! I was leaving in my car today, and looked over and about 5 feet of it is hanging down! It's badly cracked and is not fit for re-installing. It will have to be removed and replaced. All aluminum underneath. This is stiff blue plastic/vinyl.
Is this no longer available...out of stock? Andy?????
someone!?
Old 11-14-2002, 03:56 AM   #23
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Lightbulb Check'em
CAT
I betcha if you were to go to Andy's site..you'd find just the trim you need...
It's so easy to install, just use the edge of your finger nail to guide it.
ciao
53flyingcloud is offline   Reply With Quote
Old 11-14-2002, 09:12 AM   #24
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Cat.
We not only have the insert in stock, the price has dropped considerably from Airstream, as we predicted months ago.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-14-2002, 11:54 AM   #25
Cat
Cat's Avatar
Images: 8
Andy,,, I'm jazzed now; but it's only a 50 foot roll...so for my 32ft. I'll need to measure b/c it doesn't go everywhere...but I'll bet I'd need 2 rolls eh?
Is there anyone out there who bought 2 rolls that has some left over and wants to sell the difference?
.....Cat
Old 11-14-2002, 11:57 AM   #26
Commercial Vendor
Cat.
Sorry, it's available from Airstream in 50 foot rolls, only.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
800-8777311
Old 11-14-2002, 12:04 PM   #27
Cat
Cat's Avatar
Images: 8
Rolls & Partial Rolls
Thanx Andy..
.....Cat
I knew it only came in 50 ft from Airstream (you)...
what I meant by asking for partial rolls...was>>>
If anyone had bought 2 or more rolls and had a partial left over...
would THEY sell it?
Old 11-15-2002, 12:52 PM   #28
bhsl8
Profile:  1975 31' Sovereign
Eau Claire , Wisconsin
Sharing rolls
Cat, I have been planning on vinylizing (is that a word?) My 75 31 foot sovereign. I have not measured yet to see exactly how much material I would need, but if you're not in a hurry perhaps we can work something out. I have not checked prices and will try and do so but my biggest problem right now is being able to get to the unit to measure how much I need. Please let me know if you want to continue the negotiation.
Brouck
bhsl8 is offline   Reply With Quote
Caulking above blue molding ? Happycampers Leaks - Weatherstrips, Gaskets, Caulks & Sealants 19 12-11-2004 07:03 PM
86 345 AS MH Interior Molding Jim Tyrney Airstream Motorhome Forums 2 03-09-2004 07:41 AM
Lower Trim Color on 2000 Excella Cracker Clearcoat, Exterior Paint & Trim 0 01-26-2004 08:04 AM
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 05:15 PM
