Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-06-2013, 03:34 PM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
'99 Excella 1000 Lower Belt Trim Fix?
The lower strip on the front of the Otter started coming loose on this last trip. Is there a 'fix' for this and, if so, may I ask for some step-by-step instruction? Thanks.
ID:	185293   Click image for larger version
Name:	photo copy 2.JPG
Name:	photo copy 3.JPG
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 05-06-2013, 04:33 PM   #2
1981 31' Excella II
New Market , Alabama
When you pull the plastic strip out of the moulding there should be some pop rivets holding the moulding on. You can put in more rivets and fill the existing holes with rivets as well. If you don't want to put in more holes use bigger rivets. I would fix it ASAP before the floor gets wet.
Perry
Old 05-07-2013, 10:04 AM   #3
2011 31' Classic
Images: 8
Thanks, Perry. I'll try to gently pull the central plastic out and see what I see.
Old 05-07-2013, 01:27 PM   #4
1981 31' Excella II
Usually that plastic strip is anchored on both ends because otherwise it with shorten alot when the temperature changes and make gaps. Sometimes there is a cap or piece of metal at each end with a pop rivet in it. The rivet goes through the cap and into the plastic strip and then through the trim and then the trailer skin. You need like 1/2" long pop rivets to put it back together.
Perry
Old 05-21-2013, 08:14 AM   #5
2011 31' Classic
Images: 8
Got my new Stanley rivet tool and box of selected rivets. There doesn't seem to be an "end" to the plastic insert strip anywhere close to the area needing repair. I feel like I'd do lot of unnecessary damage to get to the center point behind the propane tanks. I'll try a "pull-away-and-rivet" trick unless someone else has a suggestion?
Old 05-21-2013, 08:23 AM   #6
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Greg,
If you need to replace the plastic strip, Out of Doors Mart in Greensboro, NC sells it by the foot. I had to replace some recently.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 05-21-2013, 09:16 AM   #7
1981 31' Excella II
That plastic strip is continous and it should be riveted at each end and that is why you can't find a joint. If the ends are not restrained it will gap as the temperature changes and the plastic expands and contracts.
Perry
Old 05-21-2013, 10:37 AM   #8
2011 31' Classic
Images: 8
OK, guys. Thanks. @ Chuck: Yep I use the folks at OODM as my repair and parts HQ. They're great. @Perry: I'll come up with some kind of solution.
