Old 01-09-2010, 07:21 AM   #1
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Spare tire
Has anyone purchased and installed a spare tire and holder. I need a source for the same. Any info will be appreciated.
airdreamers is offline   Reply With Quote
Old 01-09-2010, 07:35 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The tire mount can be purchased from several places. I know that Inland RV and Out of Doors Mart carry this part.
A-Frame Tire Carrier,Black 450414 [450414] - $149.95 : ODMRV , Out-of-Doors Mart
Inland RV Center Inc.
Richard
Old 01-09-2010, 08:27 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have not installed one but as I understand the process you cut out the belly pan section between the A frame, waterproof the area well, and attach the cutout section to the bottom of the floor.
I will follow this thread for my own information. Hopefully some better instructions will be posted.
Old 01-09-2010, 09:15 AM   #4
Installing Airstream's spare tire carrier, is an easy task.
Carefully, cut out the underbelly metal, that's within the A-frame, that's underneath the floor.
Reistall that removed section of metal. to the bottom of the floor.
Seal all the edge seams, with Vulkem sealer.
Install the tire carrier, in the holes that already exist.
Then, have a cool one, well maybe right now, a warm one.
The hardest part is cutting the aluminum underbelly correctly, so that the same piece will fit immediately above the place you cut it from.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-09-2010, 09:25 AM   #5
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
I'd really like to get my spare out of the truckbed and back onto the trailer (a p.o. had welded holder to the rear bumper which I promptly removed before renovating the bath). My problem is that both rear bellypan and bottom of hitch assembly drag a bit when backing into my driveway and I'm concerned that a proper tire carrier will also drag or maybe even prevent me from backing in altogether. How low do these things ride below the trailer (or just post a picture, etc). thanks
fotochop is offline   Reply With Quote
Old 01-09-2010, 09:38 AM   #6
The only part you maybe could drag, is the bootom of the tire carrier that's just below the front of the shell.
But, your Airstream may be setting too low. Have you checked the suspension system to make sure that it's supporting the coach properly, or have the rubber rods given out.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-09-2010, 09:46 AM   #7
Retired.
. , At Large
I How low do these things ride below the trailer (or just post a picture, etc). thanks
The spare tire carrier is higher than the base of the tongue jack. If the tongue jack clears without dragging, so will the spare tire.
Old 02-05-2010, 05:36 PM   #8
65CV's Avatar
Western , Massachusetts
Clearance
Is there a recommended clearance for a spare tire mounted below the a-frame?
Mine is 9" and I'm wondering if that is a little low.
65CV is offline   Reply With Quote
Old 02-05-2010, 05:54 PM   #9
Not if the axle is in good condition.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-05-2010, 07:14 PM   #10
65CV's Avatar
Thanks, Andy.
The axle is 3 years old, bought from someplace called Inland RV by the previous owner. I hear they're pretty good.
John
Old 02-05-2010, 07:18 PM   #11
Thanks, Andy.
John
They try, very hard, but as with many things in life, not perfect.
Don't worry about the spare, it's just fine.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-05-2010, 10:33 PM   #12
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
Images: 34
Do you think this would work on a Minuet, given that it is not as wide as a regular Airstream? How much would it add to the tongue weight? Is that a concern?
flcracker
georgezink is offline   Reply With Quote
Old 02-06-2010, 01:22 AM   #13
The added tongue weight for a Minuet, might be 25 to 30 pounds.
Certainly, nothing to cause any concern.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-06-2010, 07:54 AM   #14
Central , Mississippi
...(or just post a picture, etc). thanks
Well here ya go!
Name:	Spare tire holder.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-06-2010, 08:06 AM   #15
georgezink's Avatar
Images: 34
Would this fit on the A-frame of a Minuet? The Minuet is not as wide as the regular Argosy - does this mean the frame is different as well? Not worried about the ground clearance - 'cause we're riding high with the new axle...
Geo...
flcracker
Old 02-06-2010, 11:38 AM   #16
Geo...
Yes.
Andy Rogozinski
Inland RV Center
Corona, CA
Spare Tire Beverly II Tires 7 06-02-2008 04:20 PM
Spare tire. mrmossyone All Argosy Trailers 7 12-25-2007 08:19 AM
Spare Tire redneckhippy Tires 8 10-16-2007 06:17 AM
Spare tire? vajeep Tires 12 11-24-2004 12:32 PM
Spare Tire? jdleezer Tires 21 07-10-2003 07:50 AM
