Old 10-20-2014, 07:46 AM   #681
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would also like to know about any issues in this area.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-20-2014, 07:47 AM   #682
dznf0g's Avatar
Oswego , Illinois
Originally Posted by rperrym View Post
I have seen some threads about the use of Centramatics and the recommended zero offset for the nev-r-lube bearings. Has this been a problem for anyone? I would appreciate any feedback on your use of the Centramatics with these bearings.
Rick
I've experienced, nor heard of any problems. The offset with Centramatics is maybe 30 - 45 thousands inch. Maybe 1/2 - 1 mm.
-Rich-
Old 10-20-2014, 08:05 AM   #683
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
16" Wheels, Centramatics, and Nev-r-lube hubs...
I've been running 16" Sendels, Michelin Ribs, Centramatics and new Torflex axles/horizontal shocks with stock hubs since May 2012. With 16,000+ miles logged since then, I've not had a lick of problems (after having a massive Goodyear Marathon failure on right front in April 2012) with this running gear, tire/wheel configuration.
I've been practicing an annual lug nut torque/hub inspection routine just to get into the running gear for bearing inspection, lube, and general procedure. For me, it buys me peace-of-mind and a confidence knowing that the hubs are in good order as I'm rolling to the next destination. I keep spare bearings sets and a bearing/race tool kit with me at all times in case of emergency. Haven't had to use the kit on my AS, but I ran into a dude last year in CO who was experiencing a hub failure and helped him get rolling again with my kit. He had never inspected his bearings EVER since having his travel trailer - over 8 years!
I'll be keeping my standard hub/bearing set...
Be well and travel safe!
Name:	AS New Wheels and Axles Installed.jpg
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 10-21-2014, 08:36 AM   #684
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Our five SenDel T03-66655T aluminum and S62-66655SG steel spare wheels and Dill TPMS #1506 - 453 were acquired through Discount Tire. The two different sizes of Centramatics (200-221 Special for 15" wheels and 300-356 all A plates for 16" wheels) were purchased directly from Centramatic. The Michelin tires (with the 15" for the 25FB and the 16" for the 31' Classic) were purchased from and mounted by CostCo.
I did the mounting and tire swapping myself at the trailer store area. Thus I knew the torque was done correctly.
BTW. Make sure the letter of the Dill TPMS sender is chalked on the tire (I also used permanent marker on back of the wheel) so you get the right receiver programer piece into the correct space on the Dill TPMS. I learned that the hard way and CostCo had to break down the tires to figure that out for me.
Old 10-21-2014, 09:37 AM   #685
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
switz - I had Dill TPMS installed in my AS tires; I have a set to install as well in the TV tires when I get them changed. The AS ones were done at JC. Here's the issue: the wheels on my curb side register the pressure on the receiver, but those on the curb side don't. Why would this be?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 10-21-2014, 10:15 AM   #686
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
One more try on the explanation?
Just a comment, remote antenna where is it located?
I just ran mine under the cab back to the hitch area instead of CB style haven't tested yet.
GCinSC2 is offline   Reply With Quote
Old 10-21-2014, 07:37 PM   #687
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
K\I just bought a set of 16" wheels and 235/70R16 for the 1970 Overland project. I look forward to seeing how they work. The tires on the 34' are due for change out next year and I will most likely replace them with 15" LTX/MS2 They are a slightly lower profile than the existing 15" so end up 1/2 inches smaller in diameter.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-23-2014, 07:14 PM   #688
moosetags's Avatar
I got a quote back from the Airstream Service Center in Jackson Center. The cost to go 16" wheels and Michelin LT tires is now $425 per tire mounted on the Airstream.
I went through my internet research and found that performanceplustire.com had the Sendel T03 wheel (T03-66655T) with a Michelin LTX M/S 2 (LT225/75R16) mounted, balanced, and shipped for $330 per tire.
I placed an order for 5 of these tires and wheels this afternoon.
I will mount the wheels/tires myself when they arrive. I also plan to order a set of Centramatic Balancers. Does anyone have a suggestion where to order these?
Brian
Old 10-23-2014, 07:27 PM   #689
dznf0g's Avatar
Oswego , Illinois
Direct from mfr.
Centramatic Wheel Balancer, Tire Balancers for DFW Trucks
Tell them you need Airstream Special 200-221 (for 6 bolt)
-Rich-
Old 10-23-2014, 07:34 PM   #690
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by dznf0g View Post
Direct from mfr.
Ditto
Good service, no problems.
Ken
Old 10-23-2014, 07:35 PM   #691
No. 13's Avatar
2012 25' FB Flying Cloud
Boise , Idaho
Brian...direct from Centramatic...paid $216 delivered.
No. 13 is offline   Reply With Quote
Old 10-23-2014, 07:40 PM   #692
moosetags's Avatar
Direct from mfr.
Thanks for the info, Rich. I just looked on the Centramatic website. It lists the 200-221 Special for Airstream 6 bolt. Am I looking in the right place?
Brian
Old 10-23-2014, 08:04 PM   #693
dznf0g's Avatar
Oswego , Illinois
Yup, assuming you have 6 lug.
-Rich-
Old 10-24-2014, 05:21 AM   #694
switz's Avatar
2014 31' Classic
Actually, for the 16" SenDel wheels, get the proper sized Centramatic units that are slightly larger in diameter:
300-356 all A plates for 16" rims (installed on our Classic)
200-221 Special for 15” rims (installed on our 25FB)
Old 10-24-2014, 07:04 AM   #695
dznf0g's Avatar
Oswego , Illinois
I forgot about that....I had my CMs before the swap. The 200-221s work fine, but larger diameter would be better, in that thy would become effective at a lower (albeit not much) speed.
I cannot remember the man's name, but there is an obviously older man at the HQ, who know his stuff and is very helpful about AS fittings.
-Rich-
Old 10-24-2014, 07:21 AM   #696
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
The name at Centramatic was Jerry Robertson.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-24-2014, 10:02 AM   #697
moosetags's Avatar
Thanks for the info. I am going to place a call to Centramatic.
Brian
Old 10-24-2014, 01:39 PM   #698
moosetags's Avatar
I just ordered the balancers directly from Centramatic. Jerry wasn't in and I spoke to Hugh who seemed very knowledgeable about the balancers to be installed on Airstreams when switching to 16" wheels. He told me that the 200-221 Airstream Specials were the ones that I needed.
I placed the order and the total came to $213.95 including shipping.
Brian
Old 10-24-2014, 03:22 PM   #699
Shreveport , Louisiana
Did he recommend the 200-221 over the 300-356 for any particular reason ? I would think the slightly larger version would be somewhat more efficient.
Endodoc is offline   Reply With Quote
Old 10-24-2014, 03:31 PM   #700
moosetags's Avatar
I did mention to him that some folks had recommended the 300-356, and he said that the 200-221 was the one that I wanted for an Airstream that was being converted to 16" wheels. He didn't comment on the larger balancers. He seemed really knowledgeable, so I went with his suggestion.
Brian
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
