01-01-2009, 08:17 AM
1972 27' Overlander
Longmont
What is the best hitch lock??
It seems there are quite a few options for hitch locks, but not all of them work on the AS couplers with the big, rolled flange, like on my '72 OL. The Gorilla Lock, for example, only accepts the smaller flat-flange style coupler.
As far as locks that block access to the ball socket (mine is 5/16"), with the aforementioned rolled-flange all around it, what do you all think is the best coupler lock?
Happy New Year!!
01-01-2009, 10:22 AM
1963 22' Safari
2020 27' Globetrotter
State of
We have one of these on each of our trailers. Fit really well, and pretty hard to get around. Search DT Maximum Security Lock. Ebay has them, as well as a number of rv dealers. Fit large couplers really well.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
01-01-2009, 12:16 PM
1977 27' Overlander
Trotwood
tphan
The lock that I have to use is like the pic above. With the rolled lip of the coupler its about all U can use. I had about 3 different ones and had to take or send them all back because they did not fit.
They only slow down the bad guys.I do suggest that you do use something. If they are determined to take off with your trailer they will have enough equipment with them to get the job done.I even carry tools to open just about any lock in case I should become my own worst enemy and lock myself out.
One could also purchase a boot or roll control device which goes between the tires,some are locking so the trailer cannot be dragged away.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
01-01-2009, 01:04 PM
1999 23' Safari
Perrysburg
, Ann Arbor
Roger's got it right: if "they" really want it, "they" will get it ... what we're into here is "target hardening" - making your trailer less desirable in terms of ease of theft, enough of a PITA that they'll consider taking someone else's instead. So, as many locks, chocks, tiedowns, thingamajiggers as you can come up with that will slow / deter / frustrate the bad guys are all good, in my estimation.
At least, as Curly said, "It couldn't hoit!" ... that is, unless YOU forget about one of those deterrents and try to tow your trailer away yourself with some device still installed. Now, no one I know would do that of course, but I've heard tales! Good luck.
01-01-2009, 01:30 PM
Austin
I have one of these on my boat trailer:
And I have this one on my Airstream:
They both fit and work well enough, but as has been stated, they are merely a deterrent.
And I use these on all of my trailers too through the holes on the hitch lever, both when in storage and when towing:
You can buy these at places like Northern Tool or Academy.
01-01-2009, 01:33 PM
Loganville
I have mine up on Jacks and one axel off. I hope that keeps them away because I bought a universal lock at Northern Tool and it did not fit.
Lothlorian
Brian & Adrienne
01-01-2009, 01:46 PM
1977 27' Overlander
Trotwood
Brian
It should keep em away ,unless they come equipped wiffa tire and wheel and a jack to raise it off the jackstand. But that ought to keep em busy while U get the shotgun . HEY Brian/// Lead em alittle till they clear the Airstream,don't need no buckshot holes in er.
A little levity to start a new year
HAPPY NEW YEAR
Roger
Roger & MaryLou
___________________
KA8LMQ
01-01-2009, 02:05 PM
1978 31' Excella 500
Venice
You can take a spare ball with the shank cutoff and lock it in the hitch.
01-01-2009, 02:14 PM
1978 28' Ambassador
Morada
This one works rather well...the other end of the chain has a hitch ball that fits right into the coupler...
Ray & Pat; Morada, CA
01-01-2009, 02:47 PM
2007 25' Classic
kendal
, cumbria, UK
The folks here that "borrow" your trailer leave the hitch locks on and couple up with chains.
I prefer tracker devices - you get your trailer back and the bad guys get caught.
John
01-01-2009, 03:09 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
I use one of these; http://www.lifelonglocks.com very well made, with a cutoff ball in the couple.
We often leave the AS in remote NF campgrounds and go up backpacking for a few days...
If I really get concerned I take the Cobra lock from the Harley and put that through a wheel...but mostly just the LL lock and a ball.
Bill
01-01-2009, 04:23 PM
2021 27' Globetrotter
Saint Louis
This one was posted by Pahaska quite awhile ago. I got one shortly after getting our first trailer and have been happy with it. It's a Blaylock.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
01-01-2009, 09:14 PM
2007 25' Safari FB SE
Bozeman
, Montana
I have a hitch lock like Scott and Megan's, and use a cable in the wheels when in remote areas. Just to make a hard target. I have no illusions that if someone wanted it bad, they would get it. So I have insurance. And an extra set of keys.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
01-01-2009, 10:23 PM
Salem
Hi, I like the Guardian G-37 best. But I did make, and glue in place, a "U" shaped piece of tire side wall to make it fit tightly without damaging the paint on the coupler. The latch lock is a Smith & Wesson. [same as Gorilla, but different name stamped into it] Also make sure your receiver lock [not pictured] is 5/8" diameter solid shaft, not sleeved.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
01-02-2009, 08:20 AM
1972 27' Overlander
Longmont
Wow- thanks for all the good ideas! I wonder if the DT Max Security is somewhat invulnerable to bolt-cutters? Or, if Mexray's idea would work with our cat? And if the Guardian G-37 accomodates the big, rolled flange of these '70's couplers? Kinda looks like it might. Will also check out the ones Utee94 posted pics of. PM me if anyone has a flat-flange coupler that my Gorilla would work on, it's $30 plus postage. Otherwise I'm returning it.
01-03-2009, 10:44 AM
1972 27' Overlander
Longmont
So are these pretty much the choices for a durable coupler lock?
01-03-2009, 11:59 AM
1968 28' Ambassador
Cedaredge
Man I will say it again. I'm glad I live where i live. You could always jack it up and take the tires off. That would stop them from towing it away...
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
01-10-2009, 09:18 AM
1972 27' Overlander
Longmont
OK- decided to give the DT Max. Security a try- seem to be popular, widely available, and they fit the wide, rolled flange couplers. Thanks for all the advice!!
01-15-2013, 02:21 AM
1972 31' Excella 500
Mount Vernon
, Is For Lovers
Updated link for Gardian G-37
