Chaplin Kent
I also like HowieE question using 3 links. I have the basic same set up as you only I have F350 . I use 6 links under tension. I have near the same weights on every axle, I don't believe its possible to get them exactly perfect. I use 550/600 lb bars Reese Straightline.
Please do as someone suggested. GO To the CAT Scales or any state certified scale at a grain elevator or recycleing place. Take the truck there first and weight the steering and then the whole thing and then the drive. Take those weights and then hook up and reweigh, using the same scale, the same direction. Make sure the TV and Trailer are loaded full of fuel and water and the stuff you will need for an average camping trip.
I think when I weighed mine it was
Steer = 4120
Drive = 4580
Trailer=5060
Total Gross
=13760 + or - a little
GET the correct weights and make the appropriate adjustments. You can not guess this one or measure it into what you want ,Scales are the answer.
We get a very nice ride for a 1 ton and I am sure the trailer is the same, cause we leave stuff on the table and galley counter and its always there when we arrive at our destination.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
