Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 09-08-2002, 06:17 AM   #1
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Question Reese Twin Cam Setup
Hello Folks
A 750 Reese Twin Cam came with our 23 ft. Safari. I thought the back upper bars were not adjusted quite right so loosened them off and they movved about a quarter of an inch and fell into the valley of the lubricated cam. This was done with the "trailer road ready". Is this the proper adjustment for this hitch? No documentation came with the Reese. Thnxs for any info.
Old 09-08-2002, 07:27 PM   #2
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
Almost Correct
Your proceedure is almost correct.
You must have a straight line obtained for the trailer/tow vehicle by pulling it perfectly straight for 75-100 yards on level ground.
Then the trailer and tow vehicle should be checked for levelness. If the desired levelness is present, then you adjust the saddles like you did. However, they should NOT be lubed. Lubrication of the saddles prohibits the cam/saddle from being as effective in anti-sway control because the surfaces are slick with lube, and it is the friction that provides your anti-sway control. Lubing the saddles defeats your anti-sway, and should not be done at all.
Once the saddles jump into place at the top of the cam, tighten the bolts back up that hold the saddles and you are set with a perfect straight line.
Hope this helps.
dscluchfc is offline   Reply With Quote
Old 09-13-2002, 09:20 PM   #3
Road Ruler
Road Ruler's Avatar
Thnxs DSC
Thnxs for this good info. The previous owner of my Safari sold the trailer with the twin cam and "showed me" how to lube the cam area to prevent "noisy operation"??? I will remove the lube as you suggested. Thnxs again.
Old 09-14-2002, 10:50 AM   #4
Road Ruler
Road Ruler's Avatar
Hello again DSC
One more thing...
I just got out of the Reese website and found it quite good. They too say to keep the cam surfaces dry. It also said that if the noise got to be too much that vasoline could be used but best to run without the lube and accept the noise.
Old 09-14-2002, 05:10 PM   #5
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Wayne,
I've had the dual cam unit for almost 6 years. Yes, its noisy. It groans and pops, especially when you first hookup and start pulling or are backing. Don't lube the cams its very important to keep the friction on these components.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 09-15-2002, 12:23 PM   #6
Ira Iburg
Profile:
DOUBLE UP A SMALL PIECE OF ALUMIMUM FOIL AND PLACE IN THERE BEFORE HOOK UP, I ALSO HAVE USED WD40 WITH OUT ANY LOSS OF CAM ACTION
Ira Iburg is offline   Reply With Quote
Reese Friction Control or Dual Cam? donreitz Hitches 34 06-24-2004 12:43 PM
Older Reese Dual Cam for Sale Barkingspider Parts Archive 3 12-24-2003 09:34 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches 4 06-18-2003 04:50 AM
