Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 11-07-2007, 09:30 AM   #1
1976 Argosy 24
Santa Clarita , California
Question Reese Dual-cam WDH vs. Equal-i-zer Hitch
Reese Dual-cam WDH vs. Equal-i-zer Hitch:
Has anyone used both of these hitches? How do they compare in real life? There is so much theoretical info. out there on which system is better, choosing between the two is very difficult. Thanks for any real world experience you can provide.
AndyPenny is offline   Reply With Quote
Old 11-07-2007, 09:37 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
In talking to my installing RV dealer they prefer the Reese Dual Cam for larger trailers and the Equalizer for smaller ones. Equailzer does have a set up that work for my trailer but according to them it does not prefrom as well for sway control.
Michelle TAC MT-0
Sarah, Snowball
Old 11-07-2007, 10:02 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I've had a Reese HP Dual Cam for 2+ years and seen it save my trailer only once. Works for me! It seems bulletproof and I'd go that way again. I don't know that the moderate price savings would sway me to go Equal-I-Zer. But I have a couple friends who tow big 28' rigs (jcanavera's is a slideout) with an Equal-I-Zer and are happy too. This may come down to a potay-toe, potah-toe conclusion.
5 meter Langford Nahanni
Old 11-07-2007, 12:13 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I have the dual cam HP that where the brackets are bolted to the a frame.
I followed Inland RV's suggestion of not being overhitched by having too stiff weight bars while towing with a 3/4 ton Suburban.
In the end I find this setup to work extremely well. To date, I've had 2 (sane month- one year apart) situations where emergancy manuvers were required. Frankly on one of the events, if there had been a fly between the Safari and the car that all of the sudden stopped on the Interstate, it would have died from a lack of oxygen.
Old 11-07-2007, 12:26 PM   #5
My Reese rescue occurred 14 months ago on a narrow backwoods dirt road. The road was crowned and had loose gravel on the edges. I was doing maybe 25-30mph down the middle of the road raising all sorts of dust. Sightlines were not long and an oncoming pickup appeared over a rise. I moved to my right quickly and the Safari would probably have continued the sideways slide in the dry loose Class V gravel. The Dual Cam kept the Safari inline with the pickup like I was a single long school bus. The arrest of sideways motion was sudden enough to throw contents in my freezer up against the door and spill all over the floor. Believe me, I was happy with this outcome!
Old 11-07-2007, 01:11 PM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I own both. I also own a Reese with the frictional sway control. I preferred the Reese twin cam with my 31 footer when I was using the van to pull with. It was almost a necessity. It is still is nice with the dually. I do not use the Equalizer because it is too stiff vertically and would make the ride too rough for the trailer. The Equalizer is only a frictional dampening hitch. When I tow the 26 footer with the dually, I do not run WD of any type.
Old 11-10-2007, 08:10 AM   #7
holland , Michigan
I have the dual cam and into a 7k tow from michigan to southern california and back. Overall happy and i must admit little understanding of the hitch. I bought the 28 from a private owner and his navigator hitch height was about the same as our 08 f150. He was not an expert either, as he only used the 28 1 season. So, I have used 5 chain links like he did and off we went. The AS is slightly tipped forward and the truck is level???
I have been through it all, including the santa ana winds and the rig was always stable, never in any emergency situations. I like the hitch for its simplicity, and for my work I unhitch often. It does seem to conrol sway but I am interested in a HAHA. My concern is the complexity and trying to learn more about it. I do feel some sway and just got used to it, really not a big deal. Anyway it worked this long and it is a lesson basic design and construction.
safari 28 is offline   Reply With Quote
Old 11-10-2007, 10:34 AM   #8
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
i'm having one heck of a time getting my equalizer brand hitch configured on my 30 s/o and 3/4 ton suburban... it's much better than my previous 30' dinette reese WD and friction sway- but thats not saying much.
i think when you get into a combination of very heavy trailers, and approaching your TV's max ratings- the margin of acceptable configuration becomes very, very narrow
still looking for that *perfect* setup
btw- no experience with the HP dual cam... but that may change next season
boondockdad is offline   Reply With Quote
Old 11-10-2007, 11:12 AM   #9
If you raise the ball height, making the trailer level, you will increase the handling to some degree.
If the trailer is not level, when towing, then the weight on each axle is not what it should be. It should be as equal as possible.
That in itself, can create some sway.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-10-2007, 04:10 PM   #10
holland , Michigan
Wii do andy. I have about 3 more holes to go up. Big wrenches, on the road so it may have to wait. I have read many of your other post on this subject and I thank you for your input. My truck is a 08 f150 4x4 with snow plow and tow package. 5.4, 373 gears. I have noticed you feel 4x4 is a problem due to spring rates. My question is since it is a 28 footer and the 150 would have lighter spring rates than say a 250, is this why I have such good luck on this long trip? I have noticed on 5 chain links the entire vehicle come down some, and an airstream dealer that I will not mention felt the slight tip forward was good for handling. He said it cuts through the air better!! Anyway, this forum is just excellent and I learn something new everytime. Thanks again.
Old 11-10-2007, 04:15 PM   #11
JimGolden's Avatar
1977 31' Excella 500
[IMG]file:///C:/DOCUME%7E1/JIMGOL%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]Guys,
I used to use a Dual Cam when I'd borrow my dad's old camper. It did work fine. But in studying the picture, I'm not sure that I understand how it prevents sway. It looks like when you try to make a turn, the spring bar must pop out of it's detent. So when you're going straight, is the system pretty much just locked rigid, at least side to side? When you make a shallow turn, does the thing just flex enough to allow you to do it without popping the bar out of the detent?
I realize the Eq works off just straight friction. But I'm not seeing how this works at all. The gold colored arms that locate the cam fore and aft isn't going to move at all fore and aft. It could only move up and down, and that is determined by the links in the chains. So when you make a turn, the spring bars need to pull in or out depending upon which side they're on. So it looks like if you turn at all, it has to pop out of the cam lock. So is it simply that you're locked rigid when going straight and you pop it out of the cam in a turn? Could somebody explain this?
Name:	Reese Dual Cam.jpg
- Jim
JimGolden is offline   Reply With Quote
Old 11-10-2007, 04:28 PM   #12
1977 31' Sovereign
1989 34' Excella
You can not turn the unit far enough that the roller actually comes out of "what you call a detent" on the spring bar. When it does partially come up out of the bottom of the detent, there is a moment generated by this action that tries to drive the configuration back to the bottom of the detent. You need to draw a free body diagram of the trailer at the cam follower to see how it happens. You also need to draw a vertical diagram showing the sum of the moments about the trailer ball. There is also quite a bit of friction generated at the cam since it is not supposed to be lubricated and that also helps to dampen the sway moment.
Old 11-10-2007, 04:37 PM   #13
JimGolden's Avatar
I see.
With the Equal-I-Zer, the pivot point attachments for the spring bars are about 6" apart, so when you make a sharp turn, the spring bars are translating in and out several inches against the L-brackets.
But with the Reese, the pivot point attachments are really close together on the hitch head, so that when you make a turn, there is only a fraction of the in/out movement back by the cams. The Gold links hold the cam in rigid place, and the preload cranked in by the chains holds the bars against the cams. So since the bars are only moving in and out a little bit, they ride the cam lobe but don't pop off because they're not translating enough. Hence: Self centering. And when you're in the parking lot, they just pop out.
Well, that actually is pretty slick. Maybe I should have stayed with it. But I spent over $600 on the big 14K Eq and it's working fine so I'll keep what I've got. But you Reese guys, I certainly won't bash you.
I still say I need to go into the machine shop and make one similar to the Hensley where it projects the turn center 4' forward, but cheaper and easier to hitch up. Sell 'em for $800 and I could sell all I could make
Take care
- Jim
Old 11-10-2007, 05:35 PM   #14
Jim.
The Reese dual cam or straightline hitch is nothing more than a cam and saddle.
The idea is to have the torsion bars bend at least one inch or more. The more, the better up to almost 4 inches.
Assuming a correct setup and adjustment, the minimum torsion is when the rig is in a straight line.
As you turn, one bar slides forward partly up on the cam, and the other bar slides rearward on it's cam.
Because of the different angle at the end of the bars, as the movement up on the saddle continues, the torsion of each bar unequally increases.
The greater the turn, the greater unequal increase in torsion occurs.
That is why, the Reese dual cam or straightline, is said to have a brain, because the torsion, in turns becomes greater, and becomes minimum when the rig is in a straight line.
As a result of the unequal changes in torsion when the rig moves away from a straight line, it constantly seeks minimum torsion, which is getting you back into a straight line.
When the rating is correct for the rig, and it's proper installed and adjusted, you can actually make a turn of 25 to 30 degrees, and sometimes more, take your hands off the steering wheel, and the rig will return to a straight line.
Unless you have a tow vehicle that is super heavy duty, if you make a turn and stop, the tow vehicle is now tilted to one side, again because of the unequal increase in torsion when in a turn as opposed to a straight line.
It really has no choice to help you, simply because the torsion bars want to reach a minimum stress level.
Any friction type sway control, has no brain as it exerts as much friction going into a turn as it does returning to a straight line.
Also, in rainy weather, the adjustment of the amount of friction should be reduced because of the slick pavement. If not, it can keep you locked in a position when you may not want to be.
Not so with a Reese dual cam. Rain, snow, any moisture, cannot alter the changes in torsion.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-16-2008, 07:21 PM   #15
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Andy, are you in favor of the Reese dule cam over the equalizer? Also what would be the best set up for a 04 F-150 super crew pulling both a 27' Argosy and a 9,000lb boat with surge/disc breaks?
John
Argy 78 is offline   Reply With Quote
Old 02-16-2008, 08:20 PM   #16
Comparison???
Day and night.
Reese dual cam.DAY
Equalizer night, a very dark night.
The Reese knows when you turning and changes the torsion.
The equalizer has no clue when your turning.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-16-2008, 09:41 PM   #17
jump's Avatar
2004 31' Classic
lubbock , Texas
John
surely you don't mean at the same time?
jump is offline   Reply With Quote
Old 02-16-2008, 11:34 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Comparison???
Day and night.
Reese dual cam.DAY
Hi, could you be more specific about the night part; ["a very dark night"] My tow vehicle and trailer combination has no problems of any kind while turning, going foreward or backward. [Equal-i-zer] I don't feel that I need any torsion correction while turning. [My opinion]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 02-17-2008, 04:32 AM   #19
When you make a turn, the Reese dual cam torsion bars, unequally increase the torsion, to increase the sway control. That also permits, within reason, taking your hands off the steering wheel, and the rig will return to a "straight line."
That's where the name came from.
In the case of the Equalizer, in a turn, it does not increase the torsion on the bars, therefore the bars have no idea if your turning or in a straight line.
Same is true for a "friction type" sway control. It has no idea if your in a straight line or not.
A load equalizing hitch that alter what it does, depending on what the rig is doing, is far superior.
Hensley hitches, also have a brain, but costs a lot more than the Reese.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-17-2008, 06:00 AM   #20
fort atkinson , Wisconsin
In a previous post you refered to the need to reduce the tension on a friction type sway control when on slick pavement. Yet this is not necesesary with the Reese dual cam. How does the Reese dual cam know that the pavement is slick?
smthbros is offline   Reply With Quote
TT sway w/ Equal-I-Zer or Reese Dual Cam hiker Hitches, Couplers & Balls 79 09-13-2007 11:34 PM
Reese Dual Cam or Equal-i-zer ? LuminumTraila Hitches, Couplers & Balls 48 05-13-2006 12:44 PM
Equal-I-zer v/s Reese dual cam blucloud Hitches, Couplers & Balls 15 02-11-2006 03:25 PM
Reese vs. Equal-i-zer joshua32064 Hitches, Couplers & Balls 11 10-25-2003 07:44 PM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
