Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 09-22-2003, 09:46 PM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Reese drawbar & platform
I have a new Reese drawbar #54995 which has drop of some 10". It has worked fine except I have noticed that the platform will shift slightly forward when I brake to a stop or when taking off. It seems like the movement is only 1/8" or so but I did not notice this movement with my other Reese drawbar with this platform. I have used the same bolts, nuts and spacers. There are no spacers between the bar and platform where the bolts go through. Could it be that the holes in this bar are just a little larger than on the bar that was replaced? It doesn't seem to cause any problems but I wondered.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
What kind of Reese is it? Towster Hitches 25 01-11-2004 11:52 AM
Reese vs. Equal-i-zer joshua32064 Hitches 11 10-25-2003 08:44 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 08:53 PM
Wanted Reese hitch information cindy Hitches 5 04-09-2003 01:05 PM
Replacement Reese hitch bar davidz71 Hitches 11 02-20-2003 05:22 PM
