07-25-2013, 06:01 AM
#21
2013 20' Flying Cloud
Cream Ridge
, New Jersey
I try to get a comparison between a carpenters level on the floor (both ways) and a smaller carpenters level on the freezer plate. The freezer plate reading is important but not if it is way different from the floor reading. There was a slight difference on our 2013 FC so I split the difference and installed the outside levels. Your head should always be at the top of the hill when sleeping and you don't want the bathroom or closet doors to constantly slam shut or full open the minute you let go of them. Finding a happy medium takes a little work sometimes but it is doable and well worth it. After pulling into your site you level side to side first with ramps or whatever you use for blocking, chock your wheels, unhitch then use the tongue jack for front to back leveling then lower the stabilizers.
07-25-2013, 06:19 AM
#22
2008 16' Safari
Destrehan
, Louisiana
I keep a carpenters level near the entry door. I use that to set the level on the trailer.
07-25-2013, 07:03 AM
#23
1971 21' Globetrotter
Arvada
legos under the wheels for side to side and tongue jack for forward and aft. I use a carpenters level when I remember to put one on board. My interior is not done yet so I'm always removing my camping gear to work on it and forget to put the level back in. A easy replacement is to fill a glass of water almost to the top, put the glass on the floor and look at your new bubble level. If you fill the glass with your favorite beverage it my take several glasses to make sure your trailer is truly level. After several attempts it just doesn't matter anymore.
07-25-2013, 07:33 AM
#24
Milford
, Ohio
I have a level mounted by a lower corner of the front window. Its one of those large levels made with a curved plastic tube and has a large metal ball inside. See the link: Camco 25563 RV AccuLevel : Amazon.com : Automotive
Once I have the trailer positioned on a campsite, I can see from the driver's seat how far off of level the trailer is, side to side.
Sometimes backing in or pulling forward a little will do the trick, but if not, I can tell from experience by the position of the ball in that level what I will need under the trailer wheels, be that some 1x or 2x planks. I have a nice collection of leveling planks that I always travel with.
Lay those planks beside the trailer wheels on the low side, pull forward enough to get the planks into position and then back up onto them.
The level on the trailer also has a small bubble level that indicates front to back pitch. Once the trailer is disconnected from the truck you just use the power jack to get that level.
I make a final check with a small bubble level in the fridge.
Christopher
Its a camper, therefore it leaks.
07-25-2013, 07:52 AM
#25
2008 27' International FB
Petaluma
I bought two sets of these http://www.amazon.com/gp/aw/d/B000AA4RWM
When I set up my dual cam hitch I leveled the trailer precisely with a 4' carpenters level.
Then I stuck the Hopkins levels on for future quick set up
Looking for adventure in whatever comes our way.
- Brad
07-25-2013, 08:50 AM
#26
1960 22' Safari
in the wilderness
, The great Mojave Desert
Two purposes to leveling.
1, Fridge level to function.
2, Not roll out of bed.
So I found a counter top that was the same as the freezer bottom and use that to check level.
First do side to side and then tune front to back with the jack.
You don't have to be exact on the precise button.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
07-25-2013, 08:54 AM
#27
2010 25' FB Flying Cloud
Davenport
, Iowa
be careful pulling the tab after letting that beer roll around; you will waste alot of good beer."this BUD's on/for you"
07-25-2013, 10:09 AM
#28
Memphis
, Tennessee
Originally Posted by Silver Hawk
I was told to level the steel plate inside the freezer. The only thing important to be anywhere level in the trailer is the refrigerator. Once you have the refrigerator level - apply bubble levels outside.
Exactly
07-25-2013, 11:36 AM
#29
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Trick..
07-28-2013, 04:57 PM
#30
2013 22' FB Sport
Wichita
, Kansas
Thanks everyone! After a week in Colorado and two different camp sites I got it figured out. Here's what I learned. With the right side low the water from the A/C drips out up high next to the awning. Instead of down the drain and out by the drivers wheel well. So Over all it was an easy fix to get things close enough. Since the outside is metal and all. I have mounted one level in the wood under the forward bed that can be seen only when the outside storage door is open. As for left and right I mounted the second level with the tape method across the rear of the black/gray water sheet metal cover. I don't really like it that low to the ground, but it works for now. For what we spent you would think levels would be a standard feature. As for the floor being different than the tongue and it being different than the counter top yea how nice.
07-28-2013, 06:04 PM
#31
Retired.
, At Large
I get it close, then loosen the mounting screws of the level, and adjust the level so the bubble is in the middle...
07-28-2013, 06:14 PM
#32
WBCCI 8562
1975 31' Sovereign
Pelzer
, South Carolina
I try to find a level spot side to side, if not, got the plastic level blocks and
a large level on the face of the trailer. Next, I installed a small bubble level
near the jack, that is set up to show that the fridge is level. My 38 year old Dometic
is pampered. I have really not found any correlation between that fridge and
any surface in the trailer as far as level goes.
07-28-2013, 07:33 PM
#33
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I put the trailer in the driveway, then called up the bubble app on my iPhone and put the phone on the stove top. I then leveled the trailer to that using the tongue jack and a floor jack, then installed the stick on levels. If the stove top is level, everything else is close enough and when frying eggs they don't slide to one side of the pan.
I hate it when things slide to the edge of the pan when I am cooking.
07-28-2013, 07:57 PM
#34
2013 30' Classic
Greenwood
, Mississippi
I have come up with a new plan. I leave a small level on the floor in the curbside storage compartment- the one with the jack foot and wheel chicks. Up or down on the tongue jack until,it is level. This is what I did with out previous trailer as well.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-28-2013, 08:22 PM
#35
St Cloud
Originally Posted by NJtoNC
Psshht. I put a can Of baked beans on the floor. If it rolls fast, we got a problem. If it rolls slow, then hey, we didn't do so bad. If it doesn't move then its beer time!
I just thought of something...
Skip the beans and use the beer! Saves steps!
I think I'll use this technique...so what brand of baked beans do I need to buy? Lol
Rick
74 Sovereign
08-02-2013, 07:04 AM
#36
Vintage Kin
Fort Worth
I use a small level across the trailer tongue and the door entry. The test is whether cooking in a pan causes anything to move too far to one side. I don't worry over the fridge.
08-02-2013, 07:51 AM
#37
2012 25' Flying Cloud
Battle Lake
I agree with leveling the cooktop as the reference, everything else will be fine.
doug k
08-02-2013, 08:02 AM
#38
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use a small carpenter's level on the rear bumper for side-to-side, and then place leggos under tires if necessary. For front-to-back , I put the level on the battery box, then I go inside the trailer and open the bathroom door. If it sits half open without moving, we're good.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
08-02-2013, 08:46 AM
#39
1999 34' Excella
NE Central
, Kansas
I see that most use the bathroom door (or shower door, in my case) as indication the Airstream is level enough. Once leveling is done, however, I was prone to over torqueing the stabilizing jacks, because they squeak if not 'tight'. I've given up trying to get rid of the squeaks, and just tighten to the bare minimum. The only thing I need now is a lock on the Tongue Jack switch so innocent neighbors can't mess with my careful level job.
08-02-2013, 08:56 AM
#40
Santa Rosa Beach
I use a 12 volt DeWalt driver/drill to lower and raise Lucy's stabilizers. This gives me a consistent torque value. I don't believe that I have ever had anyone mess with my electric tongue jack.
Brian
