Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 02-27-2013, 04:37 AM   #1
hang up and drive
kry226's Avatar
2010 30' Classic
Carlisle , Pennsylvania
Hitch Latch Rebuild Kit?
I was hooking up last weekend in my driveway, which I have done dozens of times. The drive is on a sloping angle, but this go 'round I had a difficult time getting the vertical part of the latch to seat under the catch. Usually, I can use the tongue jack to raise or lower to front of the trailer and get it to seat, and doing this, I finally got it to work. However, raising the hitch a little in order to ease the link-up of my WD bars, the vertical part of the latch popped to the side of the latch catch, marring/bending that vertical part, and allowing the ball to pop off. Hope that makes sense. I know that "vertical part" has a name. But alas...
I would really like to rebuild the hitch mechanism before we get into the towing season, but my Google-foo is weak in the RV world.
Any suggestions on a rebuild kit for the late model Atwood hitch mechanism? Thanks in advance.
Kyle
2023 Ford F350 Lariat 7.3/4.30 FX4 CCLB
2010 Classic Limited 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 02-27-2013, 08:03 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I just purchased a repair kit for an Atwood coupler from: R and P Carriages. Com. The part number for a 2 5/16" ball is: 350375633069.
Old 02-27-2013, 08:07 AM   #3
Parts stocking Airstream dealers can help you.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-27-2013, 08:31 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
My first though it that you have Too much rearward pressure on the pawl of the coupler and that is forcing the pawl up against the incline in the back of the coupler. If this happens again try pulling the TV forward a Very Small amount (1/4 in.) to move the pressure to the front of the coupler. At that point the pawl should slide down the incline and allow the latch to drop into place.
2004 Excursion 4x4
Old 02-27-2013, 08:49 AM   #5
hang up and drive
kry226's Avatar
2010 30' Classic
Thanks, gents. Much obliged. I'm normally a pretty handy guy, but every now and then I find myself in the center of a perfect storm of unfavorable conditions and something usually gets broken.
Kyle
ProPride P3-1400
Old 03-05-2013, 05:03 PM   #6
hang up and drive
kry226's Avatar
2010 30' Classic
Arrived quickly. Hope to install this weekend.
Kyle
ProPride P3-1400
Old 03-05-2013, 05:11 PM   #7
Merkel , Texas
If you still haven't found the repair kit, Google for 88061 Atwood. I saw it for $23 plus on one or two web sites.
afneill is offline   Reply With Quote
Old 03-05-2013, 05:17 PM   #8
hang up and drive
kry226's Avatar
2010 30' Classic
That's the kit shown above...on my dining room table. Thanks.
Kyle
ProPride P3-1400
Old 03-05-2013, 05:59 PM   #9
2010 27' FB Classic
N/A , Texas
Let us know how the repair went. This might be a good item to have on hand, just in case.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Old 03-05-2013, 06:12 PM   #10
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you see a model number of your hitch thru the paint? Mine (2007 Classic) is stamped in the metal, don't have the number but I researched mine and it was non-servicable IIRC.
GCinSC2 is offline   Reply With Quote
Old 03-05-2013, 06:15 PM   #11
hang up and drive
kry226's Avatar
2010 30' Classic
WILCO, sir. Heck, I might even document the occasion. (And hopefully nothing else breaks.)
Kyle
ProPride P3-1400
Old 03-05-2013, 06:28 PM   #12
hang up and drive
kry226's Avatar
2010 30' Classic
Actually, I never checked. But you're telling me that a high-stress mechanism isn't serviceable? I am not doubting you, but I find that hard to believe as the only recourse would be complete R&R of the hitch.
Wow. I guess we'll find out soon. Thanks.
Kyle
ProPride P3-1400
Old 03-05-2013, 07:13 PM   #13
GCinSC2's Avatar
I'm the suggesting that the exact model number of your hitch searched on the manufacturers website will provide the factual answer. I don't have my hitch model number handy today, but I searched this a while back and IIRC, mine was not servicable at the component/repair kit level. I'm sure we'll figure it out.
Old 03-05-2013, 07:25 PM   #14
hang up and drive
kry226's Avatar
2010 30' Classic
No, I understand, and I appreciate the head's up.
Kyle
ProPride P3-1400
Old 03-05-2013, 10:20 PM   #15
2010 27' FB Classic
N/A , Texas
Thumbs up
Excellent!
Old 03-08-2013, 09:15 AM   #16
hang up and drive
kry226's Avatar
2010 30' Classic
Research complete. The part number stamped into my hitch, or A-Frame Coupler, is 88007. The attached repair instructions shows part number 88061 as the repair kit for this coupler. This is the kit I have on-hand. I'll probably do the repair this afternoon, or more likely tomorrow when the nippy wind dies down and we get a few more degrees on the mercury (the new Boondocker might get itself installed too).
More to follow.
Kyle
ProPride P3-1400
Old 03-08-2013, 09:47 AM   #17
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Hmmm, I have an '07 27FB Classic and would assume the 2 5/16" coupler on all recent Airstreams would be the same but it's always a good idea to verify part numbers. I tapped the roll pin out and found it was simple to remove and replace the latch. The reason I took mine out was to clean the old grit laden grease out of the coupler. I bought one to keep on hand as it looks like something that could cause a headache if it became a problem in some out of the way location.
One thing that has worked very well for me during the hitch/unhitch process is to chock the trailer in both directions then loosely chock the TV and leave it in neutral. The coupler will then latch/unlatch with no binding. Then when using the tongue jack to raise the combo to assist in latching the WD bars, the TV is free to move fore/aft relieving the lateral pressure on the jack post assy.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 03-08-2013, 05:34 PM   #18
GCinSC2's Avatar
Found my answer.
kry226,
OK, glad you found your repair kit very good. Now here's my Rest of the Story:
http://www.airforums.com/forums/f464...d-91132-5.html
Look at post #58, the pdf is for atwood couplers and repair kits, mine is an 81912 THUMB LATCH and on page 2 it lists latch kit as N/A.
So I haven't contacted Atwood, but looks like mine does not have a latch repair kit.
I'm giving some serious thought to NOT USING the tounge jack to set the bars as this puts the latch in the position of lifting the coupling/hitch/truck to set the bars, considering a bottle jack under the hitch head to lift and to not ask the latch to take this lift load. Comments folks?
Old 03-08-2013, 06:10 PM   #19
hang up and drive
kry226's Avatar
2010 30' Classic
kry226,
Ahh, yours is a slide out and requires a heavier rated hitch. Yours is rated at 13K while mine is at 10K. But that blows my mind that they don't make it serviceable.
As for your idea, I am not sure that the latch, when correctly done (unlike what I did) assumes much load. I'll continue to use the jack, albeit much more carefully.
Kyle
ProPride P3-1400
Old 03-09-2013, 10:47 AM   #20
hang up and drive
kry226's Avatar
2010 30' Classic
Got to the hitch this morning, and it was worse than I thought. It's a really simple, five minute job. Took some pics to share.
This part is called the shoe lock. I don't think it's supposed to look like that...
Complete. And for the moment, I don't really care that it doesn't match the Airstream gray. Once that moment passes, I'll paint it to reduce rusting. And to note, the edges of the latch handle were very sharp out of the package. I took a small file and smoothed them off.
Kyle
ProPride P3-1400
