Originally Posted by crispyboy
This must be made different than my older Hensley jack. The Hensley jack that I have near the top of the jack there is a small hole with a set screw inside on a collar. You may have to turn the jack a bit to see the set screw. It takes an allen wrench to adjust.
If the new jack is like my old one this IS the problem.
The nut on the bottom of the jack MAY be off also, but the primary issue is the set screw on the collar is loose.
By the way, the nut on the bottom of the jack is a left hand thread, (righty loosy, lefty tighty)
Taking the jack off, repairing and reinstalling is about a fifteen minute job.
There is a flat spot machined into the jack screw for the set screw to tighten against.
I went back with locktite thread locker. ( right or wrong)
1/2 Ton 4WD Truck, 72
Sovereign Hensley Arrow
